Controlling MS10 from Pro~One w/ CV
- sequentialsoftshock
- Real name: Zayne
- Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
Can this be done? Couldn't find a relevant topic, and the Korg manual I have is not very detailed on how to do CV in. For some reason I feel like I heard the MS series had a weird CV standard not conforming to other contemporary gear, but the patchbay says 0v-8v, and the P1 puts out -1v-7v, so it would appear it should be. Any suggestions? I'd like to control the MS10 with a sligtly larger & faster keyboard.
Last edited by sequentialsoftshock on Sat Dec 24, 2011 5:43 pm, edited 1 time in total.
- snod_donkey
- Gear: Moog Minimoog - SCI Pro-One - Roland Sh-101 - Yamaha XS6 - Oberheim OB-Xa - Roland TD8 - Evans super Echo Tape Loop - Memeory Man Deluxe
Re: Controlling MS10 from Pro~One w/ CV
Correct me if i'm wrong but i think the SCI puts out volts per octave but the Korgs use Hertz per octave....
If this is the case i may not work but i'm sure a converter could be found
- Stab Frenzy
Hertz per octave.
Yeah you can't plug them straight in, P1 is V/Oct and MS10 is Hz/V. Also the P1 puts out a Gate signal and the MS10 is S-Trig, so they're pretty much opposites as far as interfacing goes.
Your best bet to control it with a better keyboard is to use a midi keyboard and a midi/CV convertor that can do Hz/V. The Kenton ones are good, and you could also hook up a clock out to clock the sequencer on the P1.
edit: Just happened to see this, it's modular though... http://www.elby-designs.com/panther/ed1 ... /ed102.htm
- Real name: Zayne
Stab Frenzy wrote:Hertz per octave.
Yep, that was what I was talking about!
- snod_donkey
Hertz .... is there a joke i'm not aware of?
Maybe i should say Hertz per volt then
- Real name: Zayne
Yeah yeah...snod_donkey wrote:Hertz .... is there a joke i'm not aware of?
- snod_donkey
Wow!!
How weird....
How weird....
- meatballfulton
- Gear: Logic Pro X
Korg made a CV/gate format converter years ago...the MS02. They go for crazy prices used these days. Two weeks ago this one sold for $659 on eBay
- waveterm
- Gear: A lot more than you
Since one cannot find much alternative to the MS02, it is hardly surprising that they sell for those kind of prices.
If you´re not happy with that you could always build one yourself.
WT
WT
Just a guy with a bunch of blue things.......now, move on !
- Stab Frenzy
Well the module that I posted already is a clone of it, so there are alternatives.waveterm wrote:Since one cannot find much alternative to the MS02, it is hardly surprising that they sell for those kind of prices.
WT
- waveterm
But, it is not available.......
WT
WT
