Korg Trident vs expression pedal
philip
Real name: Philip
Re: Korg Trident vs expression pedal
Post by philip » Tue Feb 28, 2012 10:06 pm
Actually looks like that is mine on that picture)) And BTW this CHD retrofit doesn't work on mine.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Feb 29, 2012 5:55 am
Looking at the Trident schematic, I see no voltage at the jack on the synth. A little searching shows the MS-01 pedal had a 9-volt battery inside that provides the CV. Try this: jumper a 10k linear pot across a 9-volt battery. Connect the NEG of the battery to the shield of a mono cable. Connect the wiper of the pot to the center conductor. Plug that in and see if that works. If so, rig that up inside a pedal chassis (with an off-on switch).
- Confucius
