Properly Opening Korg MS10
Postby sequentialsoftshock » Tue Jan 31, 2012 3:24 am
What's the best procedure for opening an MS 10 to clean the insides?
bonne chance
sequentialsoftshock
Real name: Zayne
Band: Echo & Liora
Re: Properly Opening Korg MS10
Postby pflosi » Tue Jan 31, 2012 6:50 am
You might want to start with removing the side panels...
Here is the Service Manual (by synthfool.com)
pflosi
Postby nathanscribe » Tue Jan 31, 2012 10:19 am
Just be aware the end panels and the top/front are attached using brackets that are only screwed to each panel. I recommend leaving them attached to one of those panels so it's easier to reassemble straight.
nathanscribe
Postby sequentialsoftshock » Tue Jan 31, 2012 5:31 pm
That's why I wanted to clarify. Thanks for the manual link. It's not quite as straight forward as some other boards I've worked with.
bonne chance
sequentialsoftshock
Real name: Zayne
Band: Echo & Liora
Postby pflosi » Tue Jan 31, 2012 7:25 pm
You're welcome. Yeah the MS series is a huge PITA if you need to take out boards. Fortunately, the only thing I ever had to do was put a broken key to the bottom of the keyboard, that was easy... Good luck with it!
pflosi
Return to HELP!
Users browsing this forum: No registered users and 7 guests
