Micromoog - can't hear the sub-oscillator
Postby Scories » Tue Feb 07, 2012 3:53 am
Hello. I've received a Micromoog, even though it was safely packaged, the doubling function seems to be defective.
I can't hear the sub oscillator when I turn the knob. I only hear some sort of a phase shift and volume decrease.
Anyone knows if this is critical? Maybe a small soldering job will do...
Scories
Gear: Micromoog, JX-3P, Minikorg 700, Z1
Re: Micromoog - can't hear the sub-oscillator
Postby atkbg » Tue Feb 07, 2012 4:33 pm
First off, check the pot for dead spots. (This is more likely the cause)
If the pot is OK, the next is more difficult. You do have a dvm, right?
The sub is actually a digital chip IC 404CMOS.
I'd start by checking for 15v+ on pin 14 of the chip.
Check for 15v+ on R428. I recently seen SIP pack go on micros. They were once thought of as infallible, but are beginning to show signs of deterioration.
atkbg
Postby Scories » Tue Feb 07, 2012 6:55 pm
Thanks a lot for the advice.
Is good or bad news? I mean, is it easy (and cheap) to find that IC 404 CMOS digital chip?
My Micromoog has obviously been barely used. Sometimes, componnents just dries up when not used enough.
Scories
Postby atkbg » Tue Feb 07, 2012 11:08 pm
Don't jump to point 2 until you've tested point 1!
Just because its dark doesn't mean the sun collapsed! I might just mean you haven't turned on the light!
Check the easy stuff first. With a dvm, check the wiper on the Double pot.
We'll take it the next step *if necessary*.
atkbg
Postby Dr X » Tue Jul 03, 2018 2:49 pm
Hi,
Did you find out about this? I have the same problem myself, would be great with some more information.
Dr X
Postby Broadwave » Wed Jul 04, 2018 7:22 am
Scories wrote:Thanks a lot for the advice.
Is it easy (and cheap) to find that IC 404 CMOS digital chip?
IC404 is a simple CMOS CD4013 Dual Flip-Flop (14pin DIP). You can get them very easily for £0.36p/€0.40/$0.50 - Farnell, Mouser, Radio Spares etc.
Broadwave
Real name: Andy
Gear: Kronos 2-88, System 8, MODX6, ARP Odyssey, BroadWAVE ARP 2600EX, BroadWAVE Modular, BroadWAVE Sparta, BroadWAVE Minimoog, oh... and some guitars.
Return to HELP!
Users browsing this forum: No registered users and 10 guests
