Korg ESX fixer upper
Silverfish
Real name: Tyler
Band: Silverfish
Post by Silverfish » Sat Feb 11, 2012 11:08 am
Hey team-
You're always very helpful around these parts, and I'm looking for a little repair advice. I've got a Korg ESX that had knob jitters and a blown fuse. Now it's got severe knob jitters, a stuck note, and all potentiometers are only going from 0-74. I may have botched the fuse replacement.
I hate this thing so much. I have never regretted buying a piece of gear as much as this. I want to sell it, but it's worth virtually nothing in the state that it's in. I might as well try and fix it.
I'm wondering if when I replaced the fuse, I shorted something out, hence all of the spooky voodoo. Or, the stuck note is caused by a wonky touch ribbon.
Any help on this one would be greatly appreciated. Thanks!
divineaudio
Gear: far too much.
Band: metria
Re: Korg ESX fixer upper
Post by divineaudio » Sun Nov 25, 2012 7:00 pm
I had to replace the fuse in mine and it is definitely not something i recommend doing unless you have experience with smd components. did you check for any solder bridges around the fuse that may be shorting? should be visible with a magnifying glass and a bright light. if there are any, you can probably clean them up with some copper wick or a solder sucker.
for the knob jitter issue, i read on the korg forum that another person fixed his by putting a sheet of paper between the circuit boards to stop the top one from contacting the bottom one. damned if i can't find the thread though.
don't know what to say about the stuck note, but maybe if you get the other issues sorted it will work itself out.
edit - found it. - http://www.korgforums.com/forum/phpBB2/ ... hp?t=70030
balma
Real name: Mauricio
Post by balma » Mon Nov 26, 2012 1:31 am
http://www.vintagesynth.com/forum/viewt ... =3&t=68907 there you go...
The fuse can be replaced even by almost anyone. I paid $10 for the fix on a local electric service shop...
https://soundcloud.com/balma
