dead microkorg
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Fri Feb 17, 2012 7:41 am
i will check. will keep you posted. not sure what i am going to do depending on the outcome. i still may sell it if it works or not. if it's dead, of course for parts.
Steve Jones
Real name: Steve
Re: dead microkorg
Post by Steve Jones » Fri Feb 17, 2012 1:07 pm
Microkorgs have no protection diodes on the power input. Using a reversed or incorrect adaptor usually results on surface mount components being literally blown off the circuit board. A very common problem unfortunately that could have been avoided for a few cents per synth.
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Fri Feb 17, 2012 5:16 pm
that sucks. so what is it worth for parts? it is in mint condition? may need to sell it.
garranimal
Re: dead microkorg
Post by garranimal » Sat Feb 18, 2012 12:58 am
Steve Jones wrote:Microkorgs have no protection diodes on the power input. Using a reversed or incorrect adaptor usually results on surface mount components being literally blown off the circuit board. A very common problem unfortunately that could have been avoided for a few cents per synth.
Makes you wonder what other corners were cut. Whatever happened to things built to last? Back in the day product level replacement was a last resort. Now its about the only resort. :(
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Sat Feb 18, 2012 4:10 am
man..i hope batteries work? prob dead though..:(..testing monday! wish me luck~
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Mon Feb 20, 2012 11:01 pm
got it all apart..ahh! i see a blown circuit plain as day. i think only IC5 is bad...a voltage regulator? fixable? hope it's the only issue. C17 looks black a bit from the blowout. maybe replace as well? sea pic i posted. i can't seem to find a pic of the microkorg motherboard on the net to see what should be there? great looking synth..but wont turn on..:( i can see why! just the two audio in lights will light green then fade. been reading alot on this issue of wrong adapters causing the blowout! let's see if i can get a $30 buy up and running...
http://imageshack.us/photo/my-images/23/tim001r.jpg/
adhmzaiusz
Re: dead microkorg
Post by adhmzaiusz » Tue Feb 21, 2012 2:19 am
there ya go... that part sure went hard. should be fixable, just some patience and perseverance. its hard to tell how bad the damage is to the traces, but you could probably use nail polish remover to expose a new part of the trace, and with some rosin flux and some careful soldering you could probably successfully fix this.
adhmzaiusz
Re: dead microkorg
Post by adhmzaiusz » Tue Feb 21, 2012 2:25 am
part is: s-8520f33mc
description: DC/DC Switching Regulators 3.3V Step-Down PWM
unfortunately digikey and mouser is non-stocked. might take some more digging.
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Tue Feb 21, 2012 3:19 am
thanks. a bit unsure i am the guy for the repair though! a friend in texas said ..
matt-" You can always bypass burned traces, but given that is the voltage regulator, you'll need some pretty thick wire due to large current requirements. I think the first thing is to ensure that the main CPU board is still functional.You're in luck that the Hitachi H8 CPU doesn't have embedded ROM - that makes it theoretically replaceable. I think the 3.3V supply is a basic switching power supply - there is no magic to the S-8520 except it is matched to the external components. I would try to ensure that the remainder works on an external 3.3V supply. You can always work around the power supply - I don't think there is anything oddball or magical going on with that.There should be a wire from the power supply to motherboard (pg 5 of schematic - 3.3v digital.). All that P/S is doing is converting 9 v to 3.3 v in an efficient manner. You theoretically could completely bypass the p/s by providing 3.3 V as long as your external supply can source enough current."
sequentialsoftshock
Real name: Zayne
Gear: Pro One, Analog Keys, Prophet 5, MPC60, TR606, RD8, St. Vincent Guitar, Bluesbreaker amp
Re: dead microkorg
Post by sequentialsoftshock » Tue Feb 21, 2012 6:32 pm
man-009: Can't reply to you because you have disabled private messages...
gearfixer
Gear: ARP Pro DGX, Avatar, EX 800, RS101, VK-8M, Juno 60, 200a, Fast 5, and Rhodes MK1 stage 73.
Re: dead microkorg
Post by gearfixer » Tue Feb 21, 2012 8:06 pm
adhmzaiusz wrote:part is: s-8520f33mc
I tried to repair a MicroKorg 2-3 years back and I too could not fine the part till I googled it. I found a Sony service manual for a hand held recorder with the s-8520f33mc part on its part list. I went to a local electronics shop that I work from now and got the part for way to much money and I still could not get it to work. I also changed 2-3 other parts and still could not repair it.
http://www.ebay.in/itm/S-8520F33MC-SMD- ... 0228730458
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Wed Feb 22, 2012 9:13 pm
synth was sent out to matt who knows his stuff! will let you know how it pans out with the repair!
gearfixer
Re: dead microkorg
Post by gearfixer » Fri Feb 24, 2012 1:20 am
man-009 wrote:synth was sent out to matt who knows his stuff! will let you know how it pans out with the repair!
I Would like to know!
The person who owned it would like to get all the setting out of it. The thing was done form the being on the road but and was part of there bands sound.
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Fri Feb 24, 2012 1:46 am
i'm sure the custom patches are now gone. my guess is the synth will have to be reset for factory sounds. we will see.? will let you know. the synth still may be damaged further depending how far the spike traveled.
man-009
Band: Man-009
Re: dead microkorg
Post by man-009 » Fri Feb 24, 2012 5:55 pm
i see a few more dead microkorgs on ebay now with the same prob.
