Have I broken my mint Juno 60??
nathanscribe
Re: Have I broken my mint Juno 60??
Post by nathanscribe » Mon Mar 05, 2012 7:49 pm
I'll have a look at the service notes and see what I can see. Someone might need to take a look inside and sort out a part or two - I wouldn't have thought it would be anything serious. In the meantime, if it's not a problem, don't worry too much about it.
Scottf
Post by Scottf » Mon Mar 05, 2012 8:49 pm
Thanks Nathan, appreciated!!
won't worry too much but like said cosmetically and everything else appeared completely mint on day of arrival.
Post by madtheory » Mon Mar 05, 2012 10:08 pm
Yes it's probably a dead cap, as nathanscribe is thinking it's probably one in the triggering path. A visual inspection would probably reveal it.
As for the overload- you connected a line output to a line (or mic) input. The power is never going to be enough to do any damage because the input is pretty much expecting that kind of power. All that happens is that the Juno won't understand the 1s and 0s because they're all 1s when clipped.
Scottf
Post by Scottf » Mon Mar 05, 2012 10:39 pm
Thanks MT- I think we're making progress, as
Been discussed prob. Not a whole deal to
Worry about for now but if its easily
Diagnosed and fixable, I'll be happy to
Get someone to have a look at it
Thanks for now guys, I'll leave this one
Open another while for anymore input
Cheers
Jabberwalky
Band: Variar
Post by Jabberwalky » Tue Mar 06, 2012 11:59 pm
I'd test your power source or strip. My Mg1 will get spikes to the VCA and trigger notes in certain instances.
Scottf
Post by Scottf » Wed Mar 07, 2012 2:48 am
I'm using a step down transformer-the synth is rated 100volts(smae one I use with my 106) stright into the wall..
nathanscribe
Post by nathanscribe » Wed Mar 07, 2012 12:05 pm
What step-down are you using? I've had some that caused problems.
interstellartaiga
Post by interstellartaiga » Wed Mar 07, 2012 5:36 pm
I can't help with this, but you might find it interesting that my DX7 does a similar thing on startup, but only when I press a key immediately after powering it on. It's a pulsewave-ish sound similar to yours. I never considered it an anomaly and never worried about it.
HH
Post by HH » Sat Mar 10, 2012 9:42 am
Hi,
my 60 does the same on powering on and i never actually had an in-depth thought on whether its an issue or not.
After that powering, when you switch between patch programs everything is fine, right? I wouldn't worry about it much
Scottf
Post by Scottf » Tue Mar 13, 2012 9:03 pm
Thanks everyone, essential help...
now week later not worrying to much about it.. asked a local tech guy here said prob have to test everything and not worth it, right now-might look myself see if I notice anything but won't be rushing to open it up, realistically, so
I'll get over it for now..
thanks
