ESQ-1 Failure
BlackGnosis
Real name: Stormy
Gear: See signature image.
Band: Eridani V
ESQ-1 Failure
Post by BlackGnosis » Sun Mar 11, 2012 9:24 pm
Its a plastic one, os 3.5
I'm getting it set up to run in my studio and I had my motu connected, when I rebooted my motu to test something it also rebooted the ensoniq... If I press a key its very feint.... Did my I/o just kill my newly traded synth?
Trying to fix it. Might have been damaged in shipping.
I havent really have much oppertunity to use it until lately...
All I know is I accidentally triggered a software reset and now it very faintly plays... so I'm prolly stuck with a paper weight.
either way, this points to the VCA as I can still hear something very faint.
Ashe37 wrote:I find it funny that you're a guitar pedal snob and yet don't own a single analog synth.
Real name: Unpronounceable
Band: Eridani V
Re: ESQ-1 Failure
Post by Ashe37 » Sun Mar 11, 2012 11:26 pm
:shock: :o :ugeek:
i dont see how rebooting the I/O should have any affect on the synth much less make it soft-reset...
synthparts
Re: ESQ-1 Failure
Post by synthparts » Mon Mar 12, 2012 12:01 am
Do you have another CEM3360 VCA chip you can try? It should be socketed. I have them if you need a new one.
BlackGnosis
Real name: Stormy
Band: Eridani V
Re: ESQ-1 Failure
Post by BlackGnosis » Mon Mar 12, 2012 12:55 am
Ashe37 wrote::shock: :o :ugeek:
It makes it soft reboot.
Band: Eridani V
Re: ESQ-1 Failure
Post by Ashe37 » Mon Mar 12, 2012 1:02 am
crack it open and make sure all the connections to and from the PSU are good.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: ESQ-1 Failure
Post by rhino » Mon Mar 12, 2012 3:39 am
Go into the MASTER menu and check that the PEDAL input has not gotten reset to VOLUME - unless you do HAVE a pedal connected. If the pedal is set for voulme and there is no pedal connected, the synth volume is set to minimum.
If no joy, try another soft reset.
- Confucius
Synthead
Real name: Max
Re: ESQ-1 Failure
Post by Synthead » Thu Mar 15, 2012 1:54 am
If you send too many MIDI events to the ESQ-1, like in a feedback loop, it will crash and say "system error xx". I've done this a few times on accident and it's a non-issue. I was even convinced that my ESQ-1 was broken one night until I saw that my MIDI patch bay was lit up :D
