Yamaha CS-10 Triggering Problem
Posted: Tue Apr 10, 2012 5:30 pm
by BerlinRain
Hello VS!
A mere coincidence that my registering and my synth going weird happened within 10 minutes of each other I can assure you!
I did search for this problem but didn't know quite how to condense it into a search parameter so didn't find anything.
My CS10 seems to be stuck on Hold whether it is on it or not - it plays different keys that I use and everything seems to function normally except the trigger light doesn't come on unless I flip between external and single trigger and it blips but is then unresponsive. So if I use a key in single trigger or multi there's no notification of signal, even though the note changes.
If I do put it on hold the volume doubles and the signal is only responsive to sustain level in the VCA
No idea what is going on - help please!
