Ensoniq ESQ-1 as MIDI controller problems!
RoboTremulant
Post by RoboTremulant » Thu Jun 07, 2012 3:55 am
Hey there!
I've been trying to use my Ensoniq ESQ-1 as a MIDI controller to control my Doepfer Dark Energy, as a keyboard and using the sequencer. My problem is that the Dark Energy doesn't seem to be taking any information from the ESQ-1, I've tried to sync the DE to no avail, and after resetting it to factory presets (channel 1), it still doesn't do anything. I've been setting the ESQ-1 to MIDI channel 1, with Poly mode on, is there anything I'm missing? Perhaps it just needs a service and that there's something wrong with the MIDI circuit?
I'd really like to hear about any problems that have been overcome about MIDI in the ESQ-1, and about how easy or not it is to use this fellow as a MIDI controller!
gs
Re: Ensoniq ESQ-1 as MIDI controller problems!
Post by gs » Thu Jun 07, 2012 12:23 pm
Try hooking the ESQ-1 up to something else to see if the problem is indeed the unit and not something else (cable?). A good idea is to hook it up to a PC running MIDI-OX or SendSX, and see what (if any) MIDI messages the ESQ is sending out.
Note that some synths actually have a MIDI Transmit On/Off parameter stuck in there somewhere. This might be the issue.
man-009
Band: Man-009
Post by man-009 » Thu Jun 07, 2012 1:34 pm
check your midi settings on the esq-1. i ran into a same issue using it as a controller years ago. i had the wrong settings on. try some diff settings?
philip
Real name: Philip
Post by philip » Thu Jun 07, 2012 3:17 pm
try to read esq manual
