are "sawtooth" and "ramp" different terms for the same wave?
Postby chimney chop » Wed Aug 15, 2012 6:26 pm
are they?
(asking this in reference to the roland sh-2 and roland sh-5)
thanks
chimney chop
Band: boxc, cigarettes after sex
Re: are "sawtooth" and "ramp" different terms for the same w
Postby rschnier » Wed Aug 15, 2012 6:33 pm
Yes.
-- R.
rschnier
Postby chimney chop » Wed Aug 15, 2012 6:59 pm
rschnier wrote:Yes.
cool, thanks
chimney chop
Postby c-level » Wed Aug 15, 2012 7:25 pm
i thought that ramps reached their duty cicle at the end ie: /| and the sawtooth in the middle ie /|/ ? thus exciting different overtones? maybe im trippin tho...
c-level
Real name: Mike
Gear: Juno106, JX10, JX8P, JX3P, MKS50, SY22, SH201, Micromoog, CP 251, Korg Legacy, Triton Rack, Ableton 9, APC40, Max/MSP, Focusrite Pro40, Jazz Bass.
Band: C-Level
Postby Bitexion » Wed Aug 15, 2012 7:42 pm
More or less, they're just turned the "other way". Sounds the almost same no matter what way it is turned, but it interacts a bit different when you add a ramp and a saw together, more "grindy and glitchy" since they're not in phase with eachother.
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Postby Solderman » Wed Aug 15, 2012 7:45 pm
To add to the confusion, I thought ramp waves reset to minimum and increased in voltage while sawtooth waves reset to maximum and dropped to minimum. ie. always 180 degrees out of phase when they are the exact same frequency and reset simultaneously, and not at the midpoint.
"Lots of people are nostalgic for analogue. I suspect they're people who never had to work with it." - Brian Eno
Solderman
Real name: Zane W
Gear: KARP Oddy, SEM Pro, SH-101(mod), Kraftzwerg I w/MF101, CS-15(mod), µBrute, TR606(mod), TB303, α Juno 1, Поливокс(mod), Virus b
Postby Bitexion » Wed Aug 15, 2012 8:02 pm
Add two sawtooth together at the exact same volume and pitch, one saw and one ramp, and it sounds like they're fighting against eachother. I can do it on my modular. The battle of the saws!
Bitexion
Roland D-50
Creamware Minimax
Yamaha DX7s
Postby condit79 » Wed Aug 15, 2012 8:41 pm
Yeah, mixing them both together shows you that they are definitely NOT the same. It sounds super rad. I also use saw and ramp vs each other to get some crazy lfos for modulation. Reason 586 to get yourself a modular 8-)
soundcloud.com/lvoe
condit79
Gear: 5U modular/STG/.com, Mopho, Sixtrak, Sprocket, xoxbox, juno 6, ESQ1, SY35, Ipad
Band: lvoe
Postby Zamise » Wed Aug 15, 2012 9:14 pm
Saw = straight
Ramp = curved
Maybe?
Zamise
Gear: Rollhand P00
Band: Quantum-Source
Postby meatballfulton » Wed Aug 15, 2012 10:01 pm
Zamise wrote:Maybe?
BZZT, no just the polarity/phase/whatever is different.
Often seen on LFOs but not too often on VCOs except modulars
Postby Automatic Gainsay » Thu Aug 16, 2012 2:04 am
Saws are the ones that go from zero to whatever and drop off. Ramps are the ones that increase and then drop to zero. Think of it as if you're coming from the left. Saw is the one that would stop you. Ramp is the one that would make you do jumps.
There are minor audible differences... but very minor. I mean, I don't actually know... I'm just going by the Minimoog. The ramp and saw sound slightly different in comparison, but almost identical without comparison. The important difference is when they're treated as modulation sources. A ramp and a saw sound completely different in an LFO. And that's the most important part.
P.S. I recently did a shitload of videos for video education site, which are coming out soon. In them I discover that a lot of vintage synths portray their saws as ramps and ramps as saws! I can't remember which, though. Also, square waves are not square on a lot of synths.
Automatic Gainsay
Real name: Marc Doty
Band: Godfrey's Cordial
Postby Zamise » Thu Aug 16, 2012 3:05 am
Huh?
Like this:
I agree on the squares, even digital ones they seem to wobble a bit at the edges of the plateaus and troughs.
Zamise
Gear: Rollhand P00
Postby chimney chop » Thu Aug 16, 2012 3:09 am
Automatic Gainsay wrote:There are minor audible differences... but very minor. I mean, I don't actually know... I'm just going by the Minimoog. The ramp and saw sound slightly different in comparison, but almost identical without comparison. The important difference is when they're treated as modulation sources
that's exactly what i needed to know.
thanks Gainsay!
chimney chop
Postby Automatic Gainsay » Thu Aug 16, 2012 3:31 am
Zamise wrote:Huh?
Like this:
The upward saw is a ramp.
The reverse/down/backward saw is a saw.
Everything else is CRAZYTIME.
Automatic Gainsay
Postby Stab Frenzy » Thu Aug 16, 2012 3:33 am
Zamise wrote:Huh?
Like this:
The first wave you drew is a ramp, the second is a saw. The third is a ramp again. The others aren't relevant to the discussion. :thumbleft:
Next
Return to HELP!
Users browsing this forum: Bing [Bot] and 1 guest
