polysix data transfer
sam
Post by sam » Thu Sep 13, 2012 12:03 pm
Has anyone transfered patches from one too another polysix ..,?
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
rschnier
Re: polysix data transfer
Post by rschnier » Thu Sep 13, 2012 6:37 pm
Sure -- all you would need to do is save the patches onto a tape using the tape save function (a cassette recorder was what the polysix was originally designed for), then load the saved patches from the tape into the other polysix, again using the tape load function. (Note that this will overwrite the patches on the destination polysix so you'd want to save those first onto another tape, if you wanted to keep those also). The polysix user's manual also covers this of course, if you can locate a PDF on the internet someplace.
-- R.
sam
Post by sam » Thu Sep 13, 2012 8:15 pm
rschnier wrote:Sure -- all you would need to do is save the patches onto a tape using the tape save function (a cassette recorder was what the polysix was originally designed for), then load the saved patches from the tape into the other polysix, again using the tape load function. (Note that this will overwrite the patches on the destination polysix so you'd want to save those first onto another tape, if you wanted to keep those also). The polysix user's manual also covers this of course, if you can locate a PDF on the internet someplace.
Thank you but i meant from polysix to polysix...I usually dump the patches to the computer via my audio interface.
Just a thought.. :D
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Thu Sep 13, 2012 9:30 pm
Never tried it on a Polysix, but did on a pair of DW8000s - MIDI was out on one. The audio output level was too low to reliably xfer data to the other. You p'bly need to record the data into your computer and play it back into the other synth.
- Confucius
sam
Post by sam » Thu Sep 13, 2012 10:01 pm
rhino wrote:Never tried it on a Polysix, but did on a pair of DW8000s - MIDI was out on one. The audio output level was too low to reliably xfer data to the other. You p'bly need to record the data into your computer and play it back into the other synth.
O well just one of those crazy thoughts... :D
ms20/50. OBX.
Prophet 5
Wasp.EMS AKS.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Thu Sep 13, 2012 11:03 pm
Not quite as easy as plugging in a cable, but if you had some sort of small audio amp inline...
Maybe one of those tiny guitar amp/plugs used for headphone practice, or pull the guts out of a cheap cassette recorder and re-wire it. Maybe even an old powered computer speaker system.
Have you tried doing it with a cable? If the stars are right it might work - doubts tho'.
- Confucius
