Tips on SH-101 LFO repair
Solderman
Post by Solderman » Thu Dec 27, 2012 1:34 am
Believe it or not, I don't do much troubleshooting and isolation, despite my forum user name. The LFO on my SH-101 has stopped oscillating, just sending out a fixed voltage, causing D36 to stay constantly lit. Ext clock In still works.
Not currently having access to an oscilloscope, I have to guess that the problem is either IC3(IR9022) or TR4. D9 and D10 checked good. I don't know how rare these parts are either. The transistor likely has a suitable modern equivalent, but no idea on the dual op-amp.(TL022 maybe?)
Any tips for isolating a dead LFO on an SH-101? I've already gone so far as to modify an external input to replace it, although this input signal must be pre-buffered, and it doesn't go to pulsewidth. If I knew what test points to use and what voltages to check for(aside from the obvious operating voltage for IC3 and IC4), that would probably be enough to nail it.
--Solderman no more.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Tips on SH-101 LFO repair
Post by rhino » Thu Dec 27, 2012 3:13 am
Offering what thoughts I can grab:
1) Q: is the LFO locked "on"? That is, does the LFO depth slider cause the pitch to change?
2) check all 12 of the conductors on the flat cable to the control board - from the main board - in particular , #8. This runs from the RATE slider to R15 and on to the emitter of TR4.
- Confucius
Solderman
Post by Solderman » Thu Dec 27, 2012 3:28 am
It is indeed locked "ON", but I haven't yet measured the output voltage going to the mod attenuators. I did a modification replacing R15 with two resistors tied to a SPDT switch for hi/lo LFO speed, and I checked continuity to and from the switch to the holes where R15 connected to the PCB traces, checking good there. My understanding for checking transistors is they need to be checked out of circuit, so TR4 is pure speculation at this point. Continuity out of ribbon cables points 10(triangle) and 11(square) to Waveform switch and to bender board point 14 are good.
Seems to be a problem actually oscillating, but as mentioned, I don't currently have a scope to verify this.
psygoat
Post by psygoat » Thu Dec 27, 2012 5:46 pm
90% of problems on the sh101 are caused by the rubbish sliders.
Check VR10, LFO rate control, before you do anything else.
Jabberwalky
Band: Variar
Post by Jabberwalky » Wed Jan 02, 2013 6:41 am
The LFO on my Octave Kitten is also stuck "on". I'm interested in figuring this out as well. I've bombed and replaced every IC chip on the board and still no LFO oscillation.
schmidtc
Post by schmidtc » Wed Jan 02, 2013 8:31 pm
psygoat wrote:90% of problems on the sh101 are caused by the rubbish sliders.
Agreed. Many problems I've encountered on 101's are the unintuitive result of a slider failing open.
