Broken Yamaha DX7II-D Video
pflosi
Re: Broken Yamaha DX7II-D Video
Post by pflosi » Mon Feb 24, 2014 12:29 am
Ok, strange... The three reset functions I was referring to are called "erase patch map", "erase phys pres" and "erase bank [x]". If that's any help... Also, looking that up on the MK1 I just remembered: you have to do it on all banks. There's gotta be an E! manual for the II-D...
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Post by adamstan » Mon Feb 24, 2014 6:45 am
pflosi wrote:Ok, strange... The three reset functions I was referring to are called "erase patch map", "erase phys pres" and "erase bank [x]". If that's any help... Also, looking that up on the MK1 I just remembered: you have to do it on all banks. There's gotta be an E! manual for the II-D...
http://www.maths.abdn.ac.uk/~bensondj/d ... manual.zip - I've downloaded mine from this site some time ago.
JHatzia
Post by JHatzia » Mon Feb 24, 2014 9:11 pm
Any way you could upload it else where and PM me a copy? I am "Forbidden" from accessing that link you sent adamstan.
DX21
Real name: Fender
Gear: Yamaha DX21
Kawai K3
Band: AHHHH!?!!?
Post by DX21 » Fri Feb 28, 2014 6:04 pm
~Playin' Those Big Fluffy Pads at the Crack o' Dawn~
Yamaha DX7 > Yamaha SY77 > Kawai K3 > PC via Roland UM-ONE Rev 1.
JHatzia
Post by JHatzia » Mon Nov 24, 2014 6:42 pm
Happy to report I finally fixed my DX7 last night. Turned out just one wire was soldered to pin 21 instead of 20 on an IC as part of the E! Upgrade. After I corrected this I successfully transferred all the factory E! patches, buf and int sysex files to the unit. Now I have an amazing DX7IID E! This thing is nuts!
JHatzia
Post by JHatzia » Tue Nov 25, 2014 10:55 pm
Errg, scratch that. It looks like the patches didn't save over night. SO I was successfully transferring a bunch of files via MIDI, it just appears that nothing saved after it being powered off..
pflosi
Post by pflosi » Wed Nov 26, 2014 11:51 am
Exact same as mine... It's the battery. Ignore how many V are displayed (in that "check" you can do from the front panel) and just exchange it.
Weirdofromouterspace
Real name: Bodo
Post by Weirdofromouterspace » Wed Nov 26, 2014 12:25 pm
pflosi wrote:It's the battery. [...] just exchange it.
And while you're at it, install a battery clip holder. Saves you soldering the next time.
I did that with my DX21, and will do it with my DX7IID once the old battery is dead.
JHatzia
Post by JHatzia » Wed Nov 26, 2014 8:25 pm
I installed a new battery and clip holder two years ago, but when I tried to read it I was getting little to nothing. The clip holder I ordered did not fit into the sockets so it just two wires for the + and - and is hanging on its own. I'd like to redo this procedure with a proper battery and holder clip. Anything links would be appreciated. I may just check out Syntaur's site if they have these items. So happy to be soo close to making this a fully functional synth! I was playing a PPG wave patch on it that sounded amazing!
JHatzia
Post by JHatzia » Thu Dec 11, 2014 10:50 pm
Update: Installed the clip and battery. Powered up the unit and sent it Performance INT and BUF, as well as ERAM 1, 2 and 3 for the E! card as well as 5 or so E Banks of patches. The problem is this time it seems that I successfully transferred MIDI data but for whatever reason I can't scroll through the presets or different banks this time and no sound is coming out. What did I do wrong?
Good news is it seems that some patches were sent to the unit, and after turning the unit on again after a nights rest, the patches remain, so it looks like the battery is doing its job (also verified 3.33V with a multimeter)
JHatzia
Post by JHatzia » Thu Dec 18, 2014 1:53 am
Turns out that I had "Local" set to off, which should be on. All original E! patches have been sent to the unit and stay on the unit after a few days of testing. After nearly two years, I finally fixed this synth. Thank you everyone for all your help!
Case closed.
Baticuevo
Post by Baticuevo » Thu May 30, 2019 4:09 am
I need your help, seriously. Today I buy a DX7 IIFD AND I HAVE the same issue. The patches don’t save, the synth only sounds with bleeps and bells. The battery still without change, but i need help to make usable the synth, I need instructions to reset and change the battery. There is no much info about the Grey Matter E!
