Parts for Elka Synthex?
Postby Cybercardinal » Sun Jun 16, 2013 8:48 pm
How hard is it to find parts for the Synthex? (been offered one that doesn't work)
I imagine something like the joystick could prove difficult to replace.
But what about the rest? Anybody know anything?
Cybercardinal
Re: Parts for Elka Synthex?
Postby Bitexion » Sun Jun 16, 2013 10:59 pm
AFAIK the last factory made Elka Synthex went to Stevie Wonder to be used as a parts synth for his other synthex. So you might start there :P
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Postby synthparts » Sun Jun 16, 2013 11:39 pm
The Synthex uses 8 CEM3320s for its filter chips. I have them in stock if you want backups...
synthparts
Postby Cybercardinal » Mon Jun 17, 2013 8:10 pm
Thanks Doug. I will keep that in mind.
Does the Synthex have electronics that are hard to find or irreplaceable?
Cybercardinal
Postby Cybercardinal » Wed Jun 19, 2013 12:40 am
Well I found this on gearslutz:
"After having mine repaired by James at synth services in the UK due to the previous seller wiring things up wrong, i asked him about future reliability/parts etc. He told me that the synthex is not unreliable at all, its a solid unit and the parts which can fail after many years can be purchased off the shelf, theres no specialist parts, other than 1 or 2, the joystick for one of them which are not known to fail(only damaged) and can still be repaired. I dont know why people feel worried about its reliability tbh. You can fix them yourself and buy the parts off the shelf if you can work an oscilloscope."
Cybercardinal
Postby JMP » Thu Jun 20, 2013 11:41 pm
I had both of my Synthex's serviced and maintained by James Walker with no problems sourcing the bits I needed 'except' the case fan. That was replaceable but the new ones always gave a vibration/hum, even when using rubber mountings. In the end, I just put the noisy old one back in which was better than the vibration.
He also said at the time, that parts were good for at least another ten years..... That was about three years ago. I suspect they're still obtainable after that, just maybe harder to find like some other vintage synths I guess.
Buy it.... it's worth it. :)
JMP
Postby madtheory » Fri Jun 21, 2013 12:59 pm
Both? BOTH?!?!? I hate you. ;)
Band: madtheory
Postby JMP » Fri Jun 21, 2013 5:25 pm
madtheory wrote:Both? BOTH?!?!? I hate you. ;)
No need to anymore, they've both gone. :(
Despite being the best synth I've ever owned, the money the last one was worth was considered better somewhere else (in life's expenses) in the end.
JMP
Postby madtheory » Sat Jun 22, 2013 6:07 am
Ah, life.
Band: madtheory
Postby Cybercardinal » Sat Jun 22, 2013 8:53 pm
Ohh noo :cryin: I must have listened to your great demo on youtube a thousand times.
Thx for the info. I will buy it if possible
Cybercardinal
Postby alan partridge » Wed Jan 07, 2015 11:41 am
Looks like there may be a new line of parts floating around very soon, if reports of the Elka are resurrection are correct..
alan partridge
Return to HELP!
