Ensoniq ESQ1 - dead MIDI OUT help
pmanderson
Gear: RS7000, Motif XS6, Virus Indigo II, Volca Bass, Volca Keys, K Station, CZ-1, TX81Z, Matrix 1000, BCR2000, Ensoniq ESQ-1, Electribe EMX1, Prophet 08
Post by pmanderson » Tue Jun 18, 2013 11:23 am
Does anyone have experience repairing a dead MIDI OUT on an Ensoniq ESQ1?
I have a 'plastic' model. I've just recently replaced the battery and updated the OS. Everything works fine. However MIDI OUT appears to be dead. MIDI IN does work.
I've inspected the main board and see no visible signs of damage.
There is another minor issue I have that may (or may not) be related to the dead MIDI OUT.
When I move the modulation wheel to its maximum position, it appears to affect the data slider. Or at least the AD converted that samples the data slider. Its more noticeable when I focus on a parameter, filter cutoff for example, when I move the modulation near its max, the cutoff value will jump around, as if I nudged on the data slider.
Does anyone have any additional insight into these issues?
Regards,
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Ensoniq ESQ1 - dead MIDI OUT help
Post by rhino » Wed Jun 19, 2013 1:18 am
For now:
1) check MIDI menu to be sure it's on the right channel, turned ON etc.
2) Check for +5 volts on pin 4 of the MIDI OUT jack
3) There is only one active componet in the MIDI OUT circuit: a 2N3906 transistor - check it
4) Long shot: maybe something hit the plug in the MIDI OUT jack and bent/broke the jack
- Confucius
pmanderson
Post by pmanderson » Wed Jun 19, 2013 12:22 pm
Rhino
This gives me hope. I will check this out.
Thank you.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Jun 19, 2013 3:05 pm
rhino wrote:4) Long shot: maybe something hit the plug in the MIDI OUT jack and bent/broke the jack
While you check that, be sure to check the solder joints/traces where the jack is soldered onto the mainboard.
- Confucius
pmanderson
Post by pmanderson » Mon Jun 24, 2013 11:06 am
rhino wrote:For now:
I've made a couple of test without taking the synth apart.
1) MIDI setting are where they should be.
2) I'm getting +5 pm pin 4. Seems good.
3) That would be Q5 (according to schematics). I'm not sure how to test it. I have an oscilloscope but I'm waiting for better probes. Mine are shot. Should I test Q5 transistor on the board? While its turned on? And, can you suggest a testing method?
4) I don't believe this is an issue but Ill look carefully when I have the board out.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Mon Jun 24, 2013 3:57 pm
pmanderson wrote:[3) That would be Q5 (according to schematics). I'm not sure how to test it. I have an oscilloscope but I'm waiting for better probes. Mine are shot. Should I test Q5 transistor on the board? While its turned on? And, can you suggest a testing method?
While playing keys or moving mod wheel, look for pusles at the base of Q5. (the pin that goes to the DUART - pin #30)
If there are pulses there and not at the jack, (SEE NOTE)suspect the transistor. If there are NO pulses comming from the DUART, then there is deeper trouble.
NOTE: the MIDI is a current loop, so to see pulses at the jack, you will need a cable connected and plugged into a working (powered up) MIDI IN port on something else.
EDIT: Another long shot: If there are no pulses at the base of the xsistor, try re-seating the DUART chip - if socketed.
- Confucius
pmanderson
Post by pmanderson » Wed Jun 26, 2013 1:13 am
This page lists 2N3906 transistors
http://www.mouser.com/Search/Refine.aspx?Keyword=2N3906
I believe the 2N3906 type is what I need.
Can you recommend one from the list above?
I'll also be ordered 2 312-319BF-5K slide pots as well.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Wed Jun 26, 2013 1:56 am
I'd go with the first on the list.
The slide pots are (IIRC) 10k
They look like they might fit, but the shaft may be too thick for the original knobs.
I like Syntaur.com
http://www.syntaur.com/4005.html
More expensive, but their parts are first class quality and perfect fit.
- Confucius
pmanderson
Post by pmanderson » Fri Jun 28, 2013 12:32 pm
Ok, two things.
The mod wheel
I've resolved the strange mod-wheel issue where it seemed to have an effect on pitch bend and the data slider...
I calibrated it manually.
1) I unscrewed the assembly out and removed the wheel from the pot that controls the modulation; leaving the pitch-bend wheel alone.
2) With my multimeter, I measured the resistance of the pitch wheel while it was at rest in its center position. It read something like 4.32k
3) Then I adjusted the mod-wheel pot with my hand until it read exactly the same, 4.32k.
4) Put the wheel back on the modulation pot; making sure it was centered like the pitch wheel.
5) Plugged it back in, turned it on. The issue is gone. The problem doesn't show itself in the analog test procedure either.
MIDI out
After looking carefully at the ESQ1 schematic at the buchty site, I was convinced I could remove the motherboard and positively test for a bad transistor. However once I started inspecting the motherboard carefully, I realized the schematics did not match what was on the board.
The labels for the components for MIDI out (and everything else) did not reflect that what was on the motherboard.
These ESQ-1 schematics did not match my board.
http://www.buchty.net/ensoniq/files/sch ... digit1.gif
http://www.buchty.net/ensoniq/files/esq1-tg/25.jpg
However, the labels on the SQ-80 schematics for the MIDI OUT components match exactly what I was tracing in my ESQ-1 board.
http://memi.de/~buchty/ensoniq/schemati ... q80-d1.jpg
I tried to compare my motherboard with other photos of ESQ-1 motherboards and I can see the difference.
My board is labeled "Assembly ... revision J"
So the suspect transistor is NOT Q5, its Q1.
I used my multimeter's diode test and was able to see it was passing current from collector to emitter with power off. I believe that should not happen.
I will attempt to pull the transistor out tomorrow (Saturday) and replace it with a new.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Fri Jun 28, 2013 3:16 pm
Just part of the fun of vintage synths! "Let's make a production change, but updating the schematic is too much work...Who'll ever know?"
- Confucius
pmanderson
Post by pmanderson » Sun Jun 30, 2013 12:11 pm
Bummer
After replacing the Q1 transistor the MIDI out is still not working.
It had no effect.
At least I worked out a solution for the modulation wheel issue.
Thanks for your input rhino.
Regards,
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Post by rhino » Sun Jun 30, 2013 2:09 pm
Well, to paraphrase an old dirty joke: "You don't get the easy one...". Time to borrow a scope and check the output of the DUART chip - pin #30. From personal experence, recheck all traces and solder joints again - and again!
- Confucius
