Roland Tr-909 Strange issue
Posted: Wed Oct 09, 2013 11:21 am
by cutoffres
HI,
i'm repairing a TR909. Evrything is now ok except :
Even if the pattern is erased, There is always a LowTomand and a HIHat at the first step of pattern 1; pattern 3; pattern 5; pattern 7; pattern 9; pattern 11; pattern 13; pattern 15 (so every odd number)
I've replaced eprom : no success
-Maybe a switch scanning problem ? as the technical manual indicate: "... in basic opération , the cpu scans panel switches, store switch outputs, and generates trigger (TRIG) and volume (ACCENT) data for the voice generators..."
-A cpu problem ? (i doubt)
-A Ram problem ?
service maunal is here: http://privat.bahnhof.se/wb447909/dinsy ... TR-909.pdf
Any help is welcome.
Thank you
Re: Roland Tr-909 Strange issue
Posted: Thu Oct 24, 2013 7:58 pm
by AK79
Hi there,
never seen that but I would suspect the RAM because neither the CPU or the switch Matrix could produce a failure that is limited to odd numbered patterns.
cheers
Arne
