Juno 106 oscillator question.
upyoursmate
Post by upyoursmate » Fri Oct 25, 2013 6:58 pm
I can't figure out which oscillator which is causing a long wave of slightly change in frequency, when playing. Could it be something caused by the DCO?
Regards, Morten.
AK79
Gear: RolandSH09, RolandSH2, Korg PS6, Korg700S, SolinaStringEnsemble, MFOS SoundLabUltimate, YamahaDX7, YamahaCS01,SielOpera6, Korg Mono/Poly,OberheimOB8
Re: Juno 106 oscillator question.
Post by AK79 » Mon Oct 28, 2013 3:39 pm
put the Juno into Test Mode :
press & hold Key transpose and power on the synth
then press Poly 2. the number of the voice played will now be displayed when you hit a key. This helps figuring out which voice has a problem.
The DCO consists of one Master Oscillator (same for all voices) and two timers (each doing 3 voices). If one voice is out of tune, the problem may be there or in the D/A circuit which provides the CV coming from the keyboard or MIDI.
hope that helps a little.
cheers
Arne
cornutt
Gear: 6th
Post by cornutt » Tue Oct 29, 2013 7:23 pm
In my experience, the DCO timing ICs rarely fail, so if it's only one voice that's out of tune, I'd look elsewhere first. Does the out-of-tune voice sound like it has a different timbre than the rest? It could be a VCF that is out of calibration and has way too much resonance.
