Troubleshooting Help With Korg DS-8
Audity
Real name: Chris
Gear: Access Virus A, Waldorf Rocket, Alesis Micron, Yamaha DX7, etc. ...circuit bent and modded pieces
Band: (in progress!)
Post by Audity » Thu Nov 28, 2013 5:46 am
Hey all,
I picked up a Korg DS-8 at the thrift store the other day hoping it would be an easy fix. Long story short, it powers on with a blank screen and lit LEDs, but is otherwise completely unresponsive. No audio or MIDI either (although you can hear the "pop" of the op amps coming on when powering up) =/
It looked as though something sticky was spilled inside it many moons ago, most likely causing a short somewhere. I've been through the whole unit with a meter and scope, confirming that all the voicing circuitry, PSU and digital clocking all appear to be functioning. Unfortunately, I've got only a partial service manual and have diagnosed about as far as I can go.
I'm hoping somebody here may have some experience repairing these and may be able to shed some light on which IC(s) or components may be to blame for this synth failing to boot up. Any help or ideas would be appreciated! Thanks!!
REFERENCING THE PHOTO BELOW: SMD chip in the center is a proprietary Korg IC, and as such I'm assuming holds the Firmware and ROM memory. It outputs to the LED and LCD driver circuits. Traces get a little scattered going the other way, but most appear to go toward the large, through-hole IC and some of the chips around it. Can't find data sheets for most of these chips, so I'm not certain of most of their functions. All I can confirm is that they are recieving power, and most if not all are outputting signal of some sort (clock or waveform).
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Troubleshooting Help With Korg DS-8
Post by rhino » Thu Nov 28, 2013 7:02 am
These may help:
http://ebookbrowsee.net/gdoc.php?id=260 ... 1ee90a424e
http://synthedoc.free.fr/Korg/Doc/korg_ ... part_2.pdf
You may want to remove the mainboard and wash it with hot water (yes!) or electronic cleaner. Coke and beer can realy reak havoc on pc boards.
- Confucius
