Korg Micropreset M500 problems.
Europanaut
Post by Europanaut » Fri Jan 03, 2014 10:06 pm
Hey folks,
I have a Micropreset that is getting cranky.
Here's the symptoms:
On certain "patches", everything is fine. On others, some stops are missing, and the two "Synthe" buttons don't work at all.
Here are the details:
Voice - All good.
Wood - only 8 and 32 work.
String - all good.
Brass - all good.
Synthe 1 - none work.
Synthe 2 - none work.
I recently took it to a tech who decided that he wanted nothing to do with it, so I'm now on my own. I have a bit of electrical knowledge and soldering skill, so maybe with some help I can fix this neat old instrument.
Thanks everyone!
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: Korg Micropreset M500 problems.
Post by rhino » Sat Jan 04, 2014 12:31 am
First thing I'd do is a good, careful cleaning of the switches under the pushbuttons, and the rotary sound selection knob.
- Confucius
gearfixer
Gear: ARP Pro DGX, Avatar, EX 800, RS101, VK-8M, Juno 60, 200a, Fast 5, and Rhodes MK1 stage 73.
Post by gearfixer » Sat Jan 04, 2014 7:32 pm
I had one with similar problems and it was a bad trace. It does not help that they are not protected with a coating.
Mark60
Post by Mark60 » Mon Mar 09, 2020 11:43 am
Did you ever fix this? Was it a trace?
(I have one with exactly the same issues. It might be the same one, of course! Thought I'd ask before I dive in!)
Thanks!
Annie Socoria
Post by Annie Socoria » Wed Apr 01, 2020 6:35 am
I was given one of these a few years ago and finally got around to troubleshooting it this week. It appears that this exact problem (missing Wood 2'/4'/16' & both Synth sections) is very common with these synths and is due to corroded circuit traces from leaking capacitors. In my case, both C50 & C51 were leaking. The damage from C50 cut out the Wood 2'/4'/16' voices and the damage from C51 cut out the Synth sections. C32 had also leaked but did not eat all the way through the traces underneath. Bypassing the damaged traces brought the missing voices back immediately. I intend to replace all of the original electrolytic capacitors as a matter of course.
