Desktop fm synth
Desktop fm synth
I'm trying to find a desktop fm synth that is relatively portable. I was looking at buying 2 yamaha dx200s but I heard you can hear the filter stepping whenever there's a sweeping lfo, does anyone know if that's true? Also I heard you need to use the software it comes with to use it to its full potential and I'm trying to stray away from my pc as much as possible.
I was also looking at the waldorf blofeld and it seems like almost exactly what I want except that its not "true" fm synthesis.
The last synth I was looking at was either a virus c or a virus ti snow but I'm still unsure what I should get as there aren't any shops near me for me to demo them.
Can anyone recommend some other fm desktop synths?
Re: Desktop fm synth
Have you considered the PreenFM?
- meatballfulton
- Gear: Logic Pro X
The FM features found in synths like the Blofeld and Virus are nothing like the FM found in the Yamaha DX series synths.
Yes, the DX200 cannot be deep programmed without the editor and editor support ended with Mac OS 9 and WinXP. I have no idea about the filter but inside the box is a PLG150-DX board which is a full DX7-II on a board and has no filter. I believe Yamaha added a filter as part of the other circuitry in the box (the drum machine, effects, etc.).
How is fm in the blofeld different from the yamaha? Is there no dedicated fm engine on it? Everything I've seen so for from the blofeld doesn't really focus on fm that much. I'm trying to get tinny or dx7ish sounds and was wondering if that's possible with the blofeld.
- Real name: John
- Gear: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, Oberheim SEM
What all do you want out of an FM synth? If you're just wanting simpler Sega Genesis-like sounds, the Yamaha FB-01 is dirt-cheap, multitimbral, and quite compact; if you want the full DX7 experience, the TX7 is a good bit larger, but is basically a Mk.1 DX7 in a box.
I'm trying to get an fm synth I can use for drones and big chords. So the more operators the better.
- Real name: John
Yeah, the TX7 would be a great choice if you don't need multitimbrality, then. Otherwise, you could go for a rack unit and get the TX802 (a DX7-II in a box.)
yeah I need a multitimbral synth but from what I've read about the tx 802, programming it is living h**l without a PC. also I'm looking for something that I can change the parameters with in real time which I guess I should have mentioned earlier..
- fh991586
- Real name: Francis
- Gear: Roland D-50 + PG-1000, JP-8080.
Korg Kaossilator, MicroKorg,
Yamaha Motif Rack.
Midines - Location: French Canada
Affordable 80's FM doesn't really fit with real time editing...
Available for sale:
what about unaffordable
- fh991586
Yamaha Motif Rack.
Synclavier? [EDIT: Not a desktop, so forget it!]
Seriously, the Yamaha FM line is reknown for its lack of knobs, so forget deep menu diving in live action!
I can't see anything that fits your desire.
Available for sale:
- nathanscribe
- VSE Review Contributor
You can't program the TX7 from the panel. You need either software or a DX7.
From the DX/TX era, there's only the FB01 (4-op, sinewaves), the TX7 (6-op, non-programmable as standalone), or maybe the DX100 (keyboard, but small and programmable - 4-op, sinewaves). Then there was the TQ5 which was kind of a TX81Z in a desktop box (4-op, 8 waveshapes).
Afterwards the SY series had a companion set of TG desktop modules. I have no experience of those, but the SY77 is a fantastic and powerful synth that takes a lot of getting your head round - the TG77 module was, I think, the desktop version.
As for the FM in the Bolfeld, it is not as complex as Yamaha FM. In Yamaha's system, you kind of have multiple oscillators that can be independently articulated and modulated by each other in a variety of ways in particular arrangements. A great many synths use "frequency modulation" as a way of getting clangy sounds, but Yamaha's was the main method of synthesis and is much freer and more complex than just having one oscillator modulate one other.
For realtime editing on the fly with these things, you're looking at an extra knobby controller that transmits sysex/CCs. Otherwise you'll need to push a lot of buttons... though it's interesting how much less complex the DX7 seems now than it did a couple of decades ago.
I wouldn't mind jumping from page to page to change parameters as long as it works in real time so I wouldn't have to press a key again to hear what changed. and yeah I think I might actually get a preenfm or two but I'm not really that good at soldering things. thanks for the suggestions
- pflosi
Unaffordable? Any of them and this:Nnnnn wrote:what about unaffordable
Good info here by nathanscribe. I think the DX100 and / or TG line might be your best shot (they all are awesome!).nathanscribe wrote:You can't program the TX7 from the panel. You need either software or a DX7.
Forget about this though:
Not possible on any Yamaha DX AFAIK... No matter whether you dive into the menu or use a sysex/cc controller. I guess it wouldn't even work with the Jellinghaus, but then what do I know...Nnnnn wrote:I wouldn't mind jumping from page to page to change parameters as long as it works in real time so I wouldn't have to press a key again to hear what changed.
Cheers!
