Help with Yamaha SY85.
Tagore
Post by Tagore » Tue Feb 04, 2014 5:54 pm
Hello, I own a Yamaha SY85 and all of a sudden the sounds are lost, nothing can be heard with headphones or via audio out. I can't use the floppy disk or the card to restore it because both things don't function anymore. I'm sure there must be a way via menu to restore the sounds. Thank you very much.
Reconfigure
Re: Help with Yamaha SY85.
Post by Reconfigure » Tue Apr 29, 2014 2:30 pm
I don't have any experience with the SY85. But since I always have questions about things and wish they would get answered, I'll just take a guess: Local Off? I don't know how much experience you have, but it seems like something I would do with my first keyboard.
pflosi
Post by pflosi » Tue Apr 29, 2014 2:44 pm
Good call on "local midi". If it's not that, maybe the battery is empty.
Obinnamodestus
Post by Obinnamodestus » Tue Apr 24, 2018 8:54 am
Am Modestus Udemezue from Nigeria my Yamaha SY85 suddenly stop sounds but displaying what can I do
firedance1978
Post by firedance1978 » Sun Oct 21, 2018 9:00 pm
Hi Everyone!
I just bought a Sy 85 few weeks ago and the internal floppy disk do not working. I took it of and sadly found out that the belt is just disappeared from it.I have checked it online how much would be a replacement and found few of them but its expensive enough. i got an idea what if i change the old floppy drive for a new USB emulator. I found a lot of different type in a lot of different price, as from 10 eur to 150 eur. so i just got a huge confused which one would be good to buy. My question would be... is anyone here who has it done previously? Can i get advice which to buy and how to replace it? I would be so greatful for any help.Thanks and have a great music time to all of us:)Regards Tamas :)
coldwar
Post by coldwar » Mon Oct 22, 2018 2:06 pm
A lot of folks just skip the floppy drive replacement and go with an emulator such as this
You basically have a program on your PC that cuts a standard USB thumb drive into a bunch of 1.44MB partitions and lets you store files on the stick. Then you plug the stick into the GOTEK and voila! you have access to hundreds of thousands of floppy discs. Saves on disc swapping and great for storing many soundbanks/patches. It has standard floppy connector so you just pop out the old drive and this sits right in its place as a drop in solution-no soldering required. They also have ones in black color to match your Yamaha better.
Otherwise you are on the right track with just buying an old floppy drive and slapping it in there. It really should not be any more than 20 dollars for one. You could also probably just find an old cheapo tower PC on craigslist for the same amount and get it from there :) Good luck! Nice machine :)
firedance1978
Post by firedance1978 » Tue Oct 23, 2018 1:47 pm
Thank you so much. it was really helpful to me. appreciate. cheers:Tamas :) :) :) :)
