SQ80 screen and buttons freezing
dustinh
Post by dustinh » Sun Mar 02, 2014 7:25 pm
My beloved SQ80 started acting up recently. I noticed it started to happen after I was using it one day and the power went out and came back on. It was plugged in to a really good power conditioner at the time so I wouldn't think that significant damage was done to the board. The problem may have just coincidentally started around the same time.
Anyway, I turn it on, everything works just fine for a while. Sometimes it takes a couple hours, sometimes only a few minutes, but eventually the screen looks like this.
The picture is blurry, but it's two of the characters from the patch screen. I think they are the actual characters that belong there, but the screen always shows just 2 characters at different points on the screen and they are always above and below each other just like this. The patch that was loaded still plays, the mod wheel and pitch bend still resdponds, but no other buttons respond nor does the data slider. When I turn off and turn back on, everything is fine again until it will eventually repeat the same problem.
I've searched the forums here and elsewhere. I've found similar problems to this but not quite the same problem. The two suggestions I've found so far are the possibility of blown fuses inside or trying a hard reset. I've already tried a soft reset with no success. I'm inclined to think (and I'm hoping) that it's a software issue and not a hardware issue. If it were the fuses, wouldn't the problem be present as soon as I turned the board on as opposed to just occurring randomly?
How risky is doing a hard reset? I don't know a whole lot about electronics so I wouldn't want to damage the board permanently, but I think I should be able to do it as long as I take my time and carefully identify the right components to short.
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Re: SQ80 screen and buttons freezing
Post by rhino » Mon Mar 03, 2014 3:48 am
First thing I'd try is cleaning BOTH ends of BOTH the 4-wire cable from the display board to the main board and the 5-wire cable from the power supply to the display.
If no joy...
1) need to check the DUART chip - use cooling spray and see if the display comes back.
2) Remove the display/button board and try the cooling spray on the 6500 CPU chip
After that, it gets shitty. Let us know.
- Confucius
dustinh
Post by dustinh » Mon Mar 03, 2014 4:39 am
I was hoping you'd respond to this thread as I saw a thread from a while back where you seemed to know your stuff concerning the SQ80, so thanks.
I will try what you suggested in the next few days when I have a chance to take a stab at it and let you know what happens.
Jabberwalky
Band: Variar
Post by Jabberwalky » Tue Mar 04, 2014 12:18 am
Rhino is the ensoniq godfather around here.
dustinh
Post by dustinh » Sun Nov 02, 2014 9:09 pm
Well, this has taken me way too long to get to, but I'm finally working through the steps you suggested, rhino. As soon as I opened it up, it was clear that it hadn't been opened in some time. Lots of dust and hair inside. I gave everything a thorough cleaning and started out by cleaning the ends of both the 4 and 5 pin connectors and wires. After doing that, I've had the board turned on for nearly 2 hours now and so far the screen is not freezing yet. I'll let you know if it does.
dustinh
Post by dustinh » Mon Nov 03, 2014 12:55 am
And an update. I've had the synth on all day and played with it quite a bit. It still hasn't frozen. It's never gone this long without freezing so I think it's fixed. Thanks again rhino for the help!
