Korg MS20 calibration
Yekuku
Post by Yekuku » Mon Apr 14, 2014 9:20 am
hi guys, I am done recapping my MS20 and I am looking for info about how to calibrate trimmers VR1,VR2,VR3 that are found on the "jacks board" klm-128C. they seem to affect S&H, MVCA and noise but I cant find any calibration procedure in the service manual.
any ideas?
It is all about sharing...
dstrength
Re: Korg MS20 calibration
Post by dstrength » Mon Apr 14, 2014 7:32 pm
Though I haven't adjusted them on my Ms-20, from looking at the schematics, I'm guessing they are for centering up the outputs of each section.
VR1 feeds the offset terminals on that weird CA3140 op-amp voltage follower in the S&H. I think you can adjust it to center up the 5V pk-pk output.
VR2 adjusts the gain of the inverting output buffer in the Modulation VCA. Try feeding it a 5V audio signal (vco) and a 5V CV, then adjust the output for 5V pk-pk.
VR3 adjusts the pk-pk output of the noise source. Again, adjust for 5v pk-pk.
Yekuku
Post by Yekuku » Mon Apr 14, 2014 8:35 pm
Many thanks for the help Dstrength, I appreciate it.
I have noticed that there are 4 more undocumented trimmers , VR1 and VR2 on the signal processor board ( KLM-129B) and VR1 and VR2 on the filter daughterboard (KLM-307A).
Any ideas about how to calibrate these too ?
dstrength
Post by dstrength » Mon Apr 14, 2014 11:23 pm
Oh man, the pitch to voltage section is over my head. And the series of six invertors? WTF! On the ESP board, VR1 is another of those offsets on a voltage follower op amp, TL081. My guess is VR1 is for trimming the zero output state. VR2 I have no idea.
On the filter, my MS-20 has the Korg35s, so no daughter board. The schematic is here:
http://machines.hyperreal.org/manufactu ... LM-307.GIF
Those two trimmers near the diode chains are for setting the Max resonance points: the resonance at which the filter oscillates. This should be similar to the FC adjustment procedure. This gives you the ability to change where on the panel resonance (Peak in MS-20-glish) pot will lead to self oscillation. Set the filter Frequency around 5, VCO levels at 0, the dial up the resonance to see where it starts to oscillate. The manual suggests going for 500hz at a level of 10. But if your into the acid sound thing, you might want to give yourself some more room. Say, start oscillation around 7 or so.
Yekuku
Post by Yekuku » Wed Apr 16, 2014 9:39 am
Many thanks for the info and the support.
I will try the calibration later this weekend and I will keep you updated with the results.
thanks again.
Skiroy
Post by Skiroy » Sat Jul 04, 2015 7:24 pm
Does any Ms 20 owners know if it is normal for some notes to be louder than others or is this a calibration issue? Also some notes sound like the two oscillator are blended differently than others.
Yekuku
Post by Yekuku » Sat Jul 04, 2015 7:57 pm
What I have noticed with my unit is that lower notes have a higher amplitude, I thought that this was Korg's trick to make it sound more "bassy".
If you are talking about individual notes then it could be a calibration issue.
When using both oscillators , incorrect osc pitch tracking can cause abnormal frequency cancellation , thus making some notes sound softer / louder .
When using just 1 osc, are you experiencing this issue ?
sam
Post by sam » Sat Jul 04, 2015 9:37 pm
Yekuku wrote:What I have noticed with my unit is that lower notes have a higher amplitude, I thought that this was Korg's trick to make it sound more "bassy".
That's what I often find with the early versions....it almost appears that the tracking is at fault but it does add to the bass...
Lam memorymoog.Sonic six.Vp330 mk1.SH101.OSCar.ARP odyssey..multivox mx3000.Solina stringsynth.polivox
ms20/50.Andromeda. OBX.
Prophet 5 Pro-one. Wasp.EMS AKS.
