Jupiter 6 (Europa) Syncing to Sequential Circuits Drumtraks?
Posted: Sat Apr 19, 2014 3:30 am
by we_squirm
I want to sync the Arp on my Jupiter 6 (with Europa) via MIDI with my SCI Drumtraks. For some reason I can't figure this out. I know I'm missing something simple. Help?
Re: Jupiter 6 (Europa) Syncing to Sequential Circuits Drumtr
Posted: Sun Apr 20, 2014 1:55 am
by garranimal
Set the clock source to external clock sync. Per the Europa documentation which you need to look at thoroughly:
- Press and hold the DOWN button, then select bank B. Make sure bank F light is dark unless you want to be getting poly rhythms.
- Also while holding the DOWN button, the patch select buttons decide the multiplier/divider time for each step/note. Happy arpeggiating!
Posted: Sun Apr 20, 2014 3:55 pm
by we_squirm
Thanks! I'll give that a shot.
Europa is some intense stuff that I find daunting at times... :?
Posted: Mon Apr 21, 2014 8:28 am
by synthparts
Printing out a cheatsheet of the new functions and taping it to the machine helps a lot I've found...
