Ensoniq VFX SD service manual
- vcs3
- Gear: BitOne,DX7II, M-1000, ESQm, Procussion, NanoSynth, VL1, P2500, K5000R, FS1r, JX-3P, Ju-60,HR-16, CZ1000, RX-5,K2600S, Nord G1r, G2, XL-7, Shuthri-1
I just pick a Ensoniq VFX SD with a few problems and need the service manual,
anyone as it?
Thanks.
anyone as it?
Thanks.
- seamonkey
- Real name: Rick
Re: Ensoniq VFX SD service manual
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
This is a handy guide to opening the synth, and checking the PS voltages. It is NOT A SCHEMATIC. Ensoniq took them to their corporate grave.
I have tried several times to talk Creative Labs into releasing them. Most times with frankly insulting 'talk-to-the-hand' results.
- Confucius
- Confucius
- Real name: Unpronounceable
rhino wrote:This is a handy guide to opening the synth, and checking the PS voltages. It is NOT A SCHEMATIC. Ensoniq took them to their corporate grave.
I have VFX schematics...
schematics are not a service manual, either.
- rhino
- Real name: bill
- Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fair enough. Help the fellow out.
- Confucius
- Confucius
- EmptySet
- VSE Review Contributor
- Gear: MS20, x0xb0x, JV-1080, JX-3P, JX-8P(PG800), Juno Stage, VFX-SD, VL-1, ARP Omni I, D-50, DW6000
If you're like me, there's a good chance you're going to want to have Service Bulletin #12. This problem is one where it will fail calibration at boot sometimes or maybe all the time if it's really bad. (mine was intermittent). The story I read about this problem is that it plagued Ensoniq's engineers for a couple years almost. And it also affected more than one machine. I"ve even seen a document that had handwritten notes from the engineers talking to one another about the problem. They tried swapping out practically everything before they finally figured it out.
Basic gist is this… the VFX-SD has an achilles heal in its design. Namely, there are three circuitboards under the keybed that are tied together. Over time, the keybed being pressed causes this area to flex where the circuitboards are. This flexing eventually causes the ribbon cable connecting two of those boards together to fail. This will usually be seen in keyboard calibration failing at boot. But other times, it will boot just fine and even work for awhile; but as you play, the flex causes it to crash or do other weird things. It's a very common problem on VFX-SDs (and a couple other models if memory serves). If you have this problem, the good news is that the fix is pretty simple (albeit somewhat cumbersome). You simply solder new wires in place (or even in addition to) the existing ribbon cable. That's it!
Anyway, this information is hard to find despite being common. Here's a link to where you can view it.
Ensoniq approach to repair was to flip faulty boards for spares. So their is limited knowledge and docs out there. You can work through the schematics however and try to isolate problems trial/error
Gear List:
(1) Waldorf Q Yellow
(2) Waldorf Xtk
(3) Waldorf Pulse 2
(4) PPG Wave
(5) Oto Biscuit
(6) E-Mu E4XT & RFX32
Retired:
Access Virus Ti2 Polar
V-Synth
Ensoniq Fizmo
Ensoniq ESQ-M
Oberheim Matrix 1000
Waldorf Q+ (why, oh why?)
(2) Waldorf Xtk
(3) Waldorf Pulse 2
(4) PPG Wave
(5) Oto Biscuit
Retired:
V-Synth
Ensoniq Fizmo
Ensoniq ESQ-M
Actually, their eventual approach to (the keyboard) repair was to solder wires as a bridge across the two main PCBs. My 'spare' VFX has the fix done already. (I got a parts machine for nothing)
The problem with using old-style troubleshooting on any of the Ensoniq digital synths is it is going to require a waveform monitor that does above 8 MHz, a logic probe, and a lot of digital synth knowledge. Also, Ensoniq used a lot of VLSI custom chips in their synths, which makes things very difficult.
Re: Ensoniq VFX SD service manual [Schematic]
HI Ashe37,
Is there still a possibility of getting the actual Schematic for the Ensonic VFX? I'm knee-deep in troubleshooting my own VFXsd - The power supply seems to be fine, and display has heaters on but no display or even a flicker at power-up.
I have decades of servicing gear under my belt (including years of surface mount/digital work professionally), but without a road map it's really a slog! I'd love to get this up and running again for my band.
Any consideration appreciated, and all documents kept confidential
AFAIK the images of it are still on the VFX-SD yahoo group's files.MyTubeAudio wrote:HI Ashe37,
