Moog Little/Slim Phatty oscillator sync question
Postby ranzee » Mon Jun 23, 2014 10:58 am
I've setup my Slim Phatty as follows:
Modulation:
LFO RATE: Full
Source: Filt Env
Amount: Full
Destination: Pitch
Oscillators:
Wave: both to Pulse
Octave: both the same
1+2 Sync: ON
Filter:
Cutoff: Full
Res: Off
the rest probably doesn't matter so much:
KB: Off
EG: Full
O.L.: Off
Envelope Generators:
Volume:
A: Off
D: Off
S: Full
R: Off
Filter:
A: Off
D: Off
S: Off
R: Full
Here's my question
playing this adjusting the Oscillator Frequency from about 4 O'clock to 12 O'clock - I get a nice phasing sound
is there a way I can get the envelope to generate this for me?
or do I need to us CV inputs to achieve this?
ranzee
Real name: Ranz
Gear: http://www.ranzs.com/gear-list/
Band: ranzee ranz
Re: Moog Little/Slim Phatty oscillator sync question
Postby Cecil Dubreque » Wed Jun 25, 2014 9:00 pm
As you are already using the Filter Envelope as a Mod Source I don't think there is any way to execute this further modulation within the Moog alone, you could probably manage to set up some kind of MIDI CC control over the Osc Frequency if you are working with some kind of DAW but beyond that I'm not sure if it is possible. I'm not sure if you could execute this with CV either because it looks as if the CV input for Pitch will alter both Oscillators and from what I can make out the sound you are after requires the modulation of the Pitch on Osc 2 alone.... Correct me if I am mistaken.
I also have a Slim Phatty and my only major complaint about it is not being able to route the Modulation to more than one destination, I'm certain it couldn't be that difficult technically to have the LFO modulate the Pitch and Filter at the same time, but alas.
Cecil Dubreque
Postby ranzee » Thu Jun 26, 2014 12:36 am
actually since I posted this I've managed to achieve what I wanted - here's my settings:
Oscillators:
1-2 Sync On
1:
Wave: Square (65-70% or 2 O'clock)
Level: Full
2:
Freq: 55% or ~ 1 O'Clock
Wave: Square ( 65-70% or 2 O'Clock)
Level: 55% or ~ 1 O'Clock
Filter
Cutoff: 60% or 2 O'clock
Res: 0% (Off)
KB: Full
EG: Full
OL: Off
Envelopes
Vol: A: 0 D: 0 S: Full R: Full
Filter: A: 0 D: 0 S: Full R: 60% 2O'Clock
Modulation:
LFO Rate: Full
Source: Filt Env
Amount: Full
Dest: OSC2
Set the mod wheel to desired pitch
ranzee
Real name: Ranz
Band: ranzee ranz
Return to HELP!
