AN1X Service???
sol-bass-rec
Real name: Aldo Raine
Gear: Juno 106
Mophox4, MG-1, BS2
Ensoniq Fizmo
Yamaha CS6X AN1X AN200 DX200 RX11
Roland TR-808 & R8
Aira: System 1 TR-8 TB-3 VT-3
Acidlab Miami
Band: Bass Records, Suite 16, Meg Li
AN1X Service???
Post by sol-bass-rec » Mon Jul 14, 2014 5:21 pm
Yep I bought a bad AN1X off of EBAY.
It is 3 days after my Protection Period even though Ive had 2 at 44 days opened on me WTF!!!!
So I did get it to actual work fuzz free once.
Was sold as working. Seller described as "No Adapter" but "Used an adapter and it turned on. Good working condition"
Blah Blah Blah
Radio Shack adapter didn't work.
at least a dozen factory resets later it worked.
I put it up for a few weeks, during studio construction.
Bought an advertised PC-3B on ebay.
Received an LCD Monitor adapter instead. *** Opened a case on that item !!! ***
Finally received the actual PC-3B today.
Same fuzzy $&!7 c**p.
Can anybody even fix these?
I'm so angry about this whole ordeal knowing I can get somewhat similar results out of the PERFECT CS6X PLG
"Music is the drug"
Jabberwalky
Band: Variar
Re: AN1X Service???
Post by Jabberwalky » Mon Jul 14, 2014 8:47 pm
Just a thought, does it do the same thing from the headphone jack? Just try to rule out any possible issue aside from the CPU chips. Also the Cs6x w/ PLG will not do everything the An1x does. I don't have experience with those, but I remember some users here even mention that it sounds different.
sol-bass-rec
Gear: Juno 106
Mophox4, MG-1, BS2
Ensoniq Fizmo
Roland TR-808 & R8
Acidlab Miami
Re: AN1X Service???
Post by sol-bass-rec » Mon Jul 14, 2014 9:31 pm
Yes, phones, mono, left.....
white noise 90%
faint patch 10% and barely
"Music is the drug"
Jabberwalky
Band: Variar
Re: AN1X Service???
Post by Jabberwalky » Fri Jul 18, 2014 4:59 pm
Looks like this dude had the same issue, and it was the power supply. http://electro-music.com/forum/post-96216.html
Re: AN1X Service???
Post by meatballfulton » Fri Jul 18, 2014 5:22 pm
sol-bass-rec wrote:Can anybody even fix these?
A Yamaha service center probably could ;)
sol-bass-rec
Gear: Juno 106
Mophox4, MG-1, BS2
Ensoniq Fizmo
Roland TR-808 & R8
Acidlab Miami
Re: AN1X Service???
Post by sol-bass-rec » Sat Jul 19, 2014 1:48 am
Genius and the one down the road closed years back. Google should do it. Didn't know if it was a specialist needed or not.
"Music is the drug"
