korg dw 6000 just hums
Postby tjchillingham » Thu Aug 21, 2014 3:21 am
A friend gave me a Korg DW 6000. She didn't bring a cord. This unit wanted a 2 pronger. I pulled a 3 prong from an old PC, and soldered it in. Yellow on the left, black on the right, nothing to the lower pin. I plugged it in, and only get a hum. I tried different cables and amps. The hum sounds slightly different if I push some buttons. I don't know anything about synths. This unit does not have an on/off switch. It has a hole where that goes. It just powers up when you plug it in. Don't know how that happened. U.S. model. Any help is appreciated. Thanks
tjchillingham
Re: korg dw 6000 just hums
Postby rhino » Thu Aug 21, 2014 4:16 am
Welcome to the board!
By 'hum' do you mean 60-cycle?
Hold a key for about 30 seconds. If the 'hum' changes over that time, the battery has died and all programming has been lost.
If no change at all, then I'd suspect the power supply is bad.
- Confucius
rhino
Real name: bill
Gear: keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo
Postby synthparts » Thu Aug 21, 2014 12:47 pm
Yes check the power supply first in particular the large filtering caps...
synthparts
Postby tjchillingham » Fri Aug 22, 2014 1:52 am
Sorry to waste your time. I posted this while waiting for the giant pdf manual to download. The tape switch was in enable mode. Once I disabled it, the keyboard started working. I was really doubting my soldering skills for a minute. Now I want to get the factory presests back.
tjchillingham
Return to HELP!
Users browsing this forum: No registered users and 7 guests
