microbrute audio input very quiet
Is this the catch with using the analog filter? I can hardly get any usable signal. Maybe mine is faulty?
- tim gueguen
Re: microbrute audio input very quiet
What are you running into it? Perhaps your signal needs some boosting.
- pflosi
Probably a stupid question, but are you sure you've turned up the "input level" knob on the rear?
- Stab Frenzy
Also you know that the audio input goes through the filter and VCA so both of those need to be open to hear anything?
Yeah, this is totally a "gotcha"! if you're trying to inject external audio, you gotta press (and hold!) a key on the keyboard to open up the VCA.Stab Frenzy wrote:Also you know that the audio input goes through the filter and VCA so both of those need to be open to hear anything?
Welp, im a dummy. Didn't realize ya had to hold down a key.
