Polysix MIDI retrofit PS6-MRK manual
silverren
Gear: OB-8, Juno 106, many vsts
Post by silverren » Tue Oct 28, 2014 5:49 pm
Hello,
I recently got a broken Polysix with a PS6-MRK MIDI kit (made by KORG in the late 80s). It had the battery problem, but several wires from the MIDI kit are also loose inside the synth. These look to have broken off whatever ICs they were soldered to before, but I have no clue which ones. There aren't many references to this kit online, let alone a manual.
Does anyone have an installation manual for this kit available to share or purchase?
Explorer
Gear: not enough space here
Re: Polysix MIDI retrofit PS6-MRK manual
Post by Explorer » Tue Oct 28, 2014 6:07 pm
http://analog.no/cms/index.php/korg-pol ... i-retrofit
This is the usermanual for the PS6-MRK, and also includes how to perform the upgrade.
Good luck,
silverren
Post by silverren » Tue Oct 28, 2014 7:20 pm
Explorer wrote:http://analog.no/cms/index.php/korg-pol ... i-retrofit
Good luck,
Thanks, but that's a completely different kit to the one I posted. That manual quotes Korg's at the beginning but is misleading. The wires still connected on my KLM-367 board are on different ICs, with IC32 (TC5514) removed and a wire soldered into pin 8's hole.
radek tymecki
Post by radek tymecki » Tue Oct 28, 2014 7:56 pm
you have to unsolder memory ic from 367. more details will come. i've performed midi upgrade just a week ago. 2 wires to solder to memory chip, 2 other ones to other ic on 367
gearfixer
Gear: ARP Pro DGX, Avatar, EX 800, RS101, VK-8M, Juno 60, 200a, Fast 5, and Rhodes MK1 stage 73.
Post by gearfixer » Wed Sep 21, 2016 6:58 pm
I just received a Polysix with this midi kit anyone have a manual and installation manual/schematic. I repaired the KLM board but still have problems.
gearfixer
Post by gearfixer » Wed Nov 02, 2016 1:13 pm
I really could use the service/install manual for this kit!
Callockard
Post by Callockard » Sun Jul 19, 2020 6:15 am
Hi, has this ever been resolved? I have a semi-working unit with the exact same midi kit made by Korg. We may be able to help each other.
Thanks!
