hey guys, a quick question for you
i'm trying to set my arpeggiator to be synced with beat.
for example, when i hit latch to let it play a sequence as a loop, i want it to start the other sequence after the melody of the first one finishes, even if i don't hit the new sequence on the correct bar. do you know what i mean?
if not, lemme know and ill try to explain it better. sorry bout the english
thanks!
KORG MS2000 ARPEGGIATOR
