Yamaha SY85 freezes
ukbrad
Yamaha SY85 freezes
Post by ukbrad » Thu Dec 04, 2014 3:15 pm
Hi, I have inherited a Yamaha SY85. I have been playing around with it for a bit and key bashing but every now and again it freezes and hums the last note you played, and none of the buttons or keys do anything. The only way to unfreeze it is to turn it off and on again. I wondered if this was a common issue and what could be done to fix it, or I am just such a newbie i'm pressing a button which freezes the synthesizers. Thanks
ukbrad
Re: Yamaha SY85 freezes
Post by ukbrad » Tue Dec 09, 2014 4:27 pm
No suggestions?
db0451
Post by db0451 » Thu Dec 11, 2014 10:32 pm
ukbrad wrote:I wondered if this was a common issue
Not that I have heard, and I do a lot of reading about old stuff like this.
The usual suggestion is to check the voltages coming out of the power supply (PSU), and whereas that is often a red herring, in this case it might be relevant. Perhaps a CPU or something is being under- or overvolted and hanging for that reason. The usual culprits are failing electrolytic capacitors
Another thing that is always worth checking, especially because it is so simple, is to un- and re-plug all connectors between the circuit boards (PCBs) and other components inside the synth, to ensure that there are no intermittent (‘loose’) connections that sometimes cause bogus data to reach a CPU or other IC.
Again, no such button was ever provided, as far as I know! :-P
