Alpha Juno 2 Dead Voice (not voice chip)
silviu
Post by silviu » Wed Dec 24, 2014 10:36 pm
I have an Alpha Juno 2 that recently started having issues with voice 1. I traced that to voice A on the board and swapped the IR3R05 chips between voice A and B, and it made no difference. I think I can assume that the chip is not to blame. I am going to proceed with removing and testing all of the caps in voice A as I think that is the next logical step.
I wanted to check if anyone else had experienced a dead voice on an Alpha Juno or MKS-50 and if they could share any advice on what to test/where to look for issues. Thanks!
Real name: Unpronounceable
Band: Eridani V
Re: Alpha Juno 2 Dead Voice (not voice chip)
Post by Ashe37 » Thu Dec 25, 2014 1:56 am
is the VCA on the chip?
gslug
Real name: Kevin
Gear: Jupiter 6, Juno 106, MKS-50, DX7, TX81Z, Emulator II (dead), DPX-1, EPS 16 Plus, x0xb0x, Shruthi, TR-707, 9090, MIDIbox MB6582, MIDIbox Seq V4
Post by gslug » Thu Dec 25, 2014 5:47 am
I haven't experienced a dead voice, but have spent some time poking around my MKS-50 with a scope in order to diagnose a noise problem. The IR3R05 is the only active component for an individual voice, but you seem to have eliminated that as the problem. There are a few electrolytic capacitors in the area that may be suspect, as well as trim pot VR1.
If you have access to a scope, check for a signal either side of C20, which couples the DCO output to the IR3R05. Also take a close look at the soldering - my MKS-50 had some awful dry joints.
silviu
Post by silviu » Sat Dec 27, 2014 12:35 am
Yes, the chip handles the VCF/VCA.
I've removed all of the capacitors to find out that my capacitance meter does not work. So I will just replace them, I have to head to the electronics shop today anyway. See what that does.
I will also test that trim pot, thanks for the suggestion.
