Hello VSELand, my Matrix 6r is sending CC ( hex )
B0 07 00
B2 07 00
At times it does this constantly.
In my DAW, the Matrix will shut off the volume on any armed midi track. This isn't good.
Can anyone give me insite to this issue and how to resolve it on the Matrix itself?
OS 2.13
Other than that it works great, I removed the voice chips and cleaned the sockets with some high end contact cleaner and reseated them. The unit sounds cleaner.
Thanks
DX
Oberheim Matrix 6r help please, sending random cc data
- Synthetech
Re: Oberheim Matrix 6r help please, sending random cc data
maybe check to see if a pedal input is assigned to volume control?
try to disable all local pedal controls?
just a guess.. maybe a bad input is causing spurious voltages that the cpu thinks is a pedal attached and being moved.
Ok I'll look into that tonight and post back if it worked ... Otherwise I'll keep searching .Synthetech wrote:maybe check to see if a pedal input is assigned to volume control?
Thank you synthtech
