OK, the installation directions are here: http://kovariant.d250.hu/images/midi..._mod_guide.pdf
I completed steps 1-20 with no problem and then step 21 is where I don't know what to do.
"21. Unplug the 4-pole connector. With a flat screwdriver force the metal plate of the second pin and take it out." I did that successfully (pic 1)!
"21.....At the now free place put the middle wire from Minerva." The only wires from the Minerva that aren't plugged into something already, is a 2-prong connector. What "middle wire" is he talking about, and do I insert that middle wire in the terminal that I just pulled the white one from (pics 2 and 3)?
"22. There is a 2-pole connector with one wire already plugged from Minerva. My 2-pole connector that came in my kit already had 2 wires in it, not 1 (pic 1). What's up with that? What do I do with it?
"22....Put the previously removed wire at the free place of the 2-pole connector." Does this mean the white wire that I pulled in step #21 ? If so, how do I fit it into a 2-prong terminal if both terminals are filled.
I have emailed Laszlo, but I haven't heard anything back yet. I am just very antsy and exited to use this baby. If anyone could shed some light on this situation I would be very grateful.
CHEERS!
