Attaching aftertouch strip - what kind of double-sided tape?
DesolationBlvd
Post by DesolationBlvd » Fri Mar 06, 2015 4:54 pm
I finally sourced an aftertouch strip for my Alpha Juno. It wasn't the original Roland one, but I plugged it in and squeezed it, and it responded just the same.
It says I need double-sided tape to attach it. What kind of double-sided tape do I use?
Moog Matriarch
Oberheim OB-8
Sequential Prophet 2002
Ensoniq Mirage/SQ-80
Roland JP-8/SH-101/RS-09/Kiwi-30/JD-990
Yamaha TX7/DX100
Waldorf Microwave 1
Simmons SDSV/SDS9
Elektron Analog RYTM
Broadwave
Gear: Kronos 2-88, Fantom 6, System 8, MODX6, Behringer Odyssey, BroadWAVE ARP 2600EX, BroadWAVE Modular, BroadWAVE Sparta, BroadWAVE Minimoog.
Re: Attaching aftertouch strip - what kind of double-sided t
Post by Broadwave » Mon Mar 09, 2015 6:03 am
Scotch/3M double sided tape should do fine ;)
garranimal
Post by garranimal » Tue Mar 10, 2015 2:44 am
I used to do picture framing professionally. Whatever products you end up using, they are usually pressure-sensitive so press 'em down hard as you can. Give the 3m products a look and be sure to test anything before putting it to use.
I trust my sticky needs to Therm O Web Peel N Stick. Designed for scrap-booking, it does not need heat nor iron, and it grabs and holds onto virtually anything. In USA I think I got mine at a crafts store like Michaels.
I do not recommend Scotch double-sided tape, it only holds up light duty applications using paper to paper.
DesolationBlvd
Post by DesolationBlvd » Mon Mar 16, 2015 1:58 am
garranimal wrote:I used to do picture framing professionally. Whatever products you end up using, they are usually pressure-sensitive so press 'em down hard as you can. Give the 3m products a look and be sure to test anything before putting it to use.
It seems that they have a bunch of different products:
http://www.thermowebonline.com/c/crafts ... pes-sheets
It says their SuperTape is the strongest, so I should use that?
Moog Matriarch
Oberheim OB-8
Yamaha TX7/DX100
Waldorf Microwave 1
Simmons SDSV/SDS9
garranimal
Post by garranimal » Mon Mar 16, 2015 3:29 am
I'm not sure its double sided. The Mounting Adhesive Tape looks more useful to your application. The more pressure you put down, the more permanent the bond. Similar to the Peel-N-Stick sheets I've been using. Be sure to test any product first.
DesolationBlvd
Post by DesolationBlvd » Mon Mar 16, 2015 8:13 pm
garranimal wrote:I'm not sure its double sided. The Mounting Adhesive Tape looks more useful to your application. The more pressure you put down, the more permanent the bond. Similar to the Peel-N-Stick sheets I've been using. Be sure to test any product first.
I looked at the SuperTape again, and it's also double-sided.
The site says the SuperTape is meant for holding heavier things...
Moog Matriarch
Oberheim OB-8
Yamaha TX7/DX100
Waldorf Microwave 1
Simmons SDSV/SDS9
Knas
Post by Knas » Sat Sep 15, 2018 10:44 pm
Necromancing this thread... where did you get an aftertouch-strip replacement for the AJ2?
