playing drum sounds on Roland 1080
MalRoyalE
Post by MalRoyalE » Wed Apr 29, 2015 8:37 pm
Hi, I wondered how I can play the drum sounds on my Roland 1080, powered by my drum machine ( fully midi )
I don't do computer music. I want to do it all as we ever did things years ago.
I know the drum sounds are on channel 10, how do I get my drum machine to play them
Any help would be great thank you
Melvyn
max badwan
Real name: Max
Re: playing drum sounds on Roland 1080
Post by max badwan » Wed Apr 29, 2015 11:40 pm
Set the drum machine to transmit on channel 10. Assign the pads to the note-numbers you want to trigger.
MalRoyalE
Post by MalRoyalE » Thu Apr 30, 2015 11:56 pm
Ah of course, I'll try this and let you know. Thank you thank you
Mel
MalRoyalE
Post by MalRoyalE » Tue May 05, 2015 10:45 am
Ah so my very ancient RX 15 is ok to midi to a newer sound module, but choosing channel 10 is not something it seems to know about. Any ideas.
I like the RX15 cos you can alter time and tempo from bar to bar. I've used this for hundreds of recordings, and am quite accurate with it. It would be nice to continue using this unit with me new roland 1080.
Is there any way of altering the drum sounds from channel 10 ????
Ta
max badwan
Real name: Max
Post by max badwan » Tue May 05, 2015 12:12 pm
MalRoyalE wrote:Ah so my very ancient RX 15 is ok to midi to a newer sound module, but choosing channel 10 is not something it seems to know about. Any ideas.
Ta
You can't change the drum channel on the 1080, it's fixed on 10. Page 42 of the RX manual will tell you how to set the MIDI channel. (Function/MIDI IN).
MalRoyalE
Post by MalRoyalE » Sat May 09, 2015 7:23 pm
function and midi in, gets me to Omni which I switch to off, then choose channel 10 by way of data slider. Channel 10 is then set, but output still plays piano. I've tried channels 1 to 16 to see if this makes any difference, but still get piano
I've done this many times now and nothing but piano.
I like piano most of the time
max badwan
Real name: Max
Post by max badwan » Sat May 16, 2015 6:40 am
MalRoyalE wrote:function and midi in, gets me to Omni which I switch to off, then choose channel 10 by way of data slider. Channel 10 is then set, but output still plays piano. I've tried channels 1 to 16 to see if this makes any difference, but still get piano
Is the JV in performance mode? Have you tried Function/MIDI OUT as a combo?
Calgonstudio
Real name: Ric
Band: Client No7
Post by Calgonstudio » Sat May 16, 2015 7:23 pm
I have nothing to offer here, just want to find out the results......
MalRoyalE
Post by MalRoyalE » Mon May 25, 2015 10:48 am
Eureka !!!!! So yes I altered each pad to channel midi 10 and its working. there are a couple of pads that share sounds, and only one of the pad choices do the drums, but essentially this works really brill.
Yippeeeeee !!! thank you
