My Roland RS-09 recently started making a popping sound when a key is pressed. I've had it for over 10 years and I'm pretty sure it just started happening. Has anyone else experienced this before?
Here is a video so you know what I'm talking about.
It also makes the same sound when hitting the ensemble buttons.
The service manual is here.
http://www.synfo.nl/servicemanuals/Rola ... _NOTES.pdf
It is not the keys themselves and I'm pretty sure it's not a grounding issue. Some of the caps on the Gate PCB look questionable but are in spec in and out of circuit.
Any help would be greatly appreciated! I need this for a gig coming up and this sound is driving me nuts!
Roland RS-09 Popping Sound when playing keys
- HaziaJuno
- Real name: Billy
- Gear: Roland Juno 6
Roland SYSTEM-1
Yamaha DX7 mk1
Roland JX-8P
Roland JU-06
Korg MS2000
MicroKorg
Casio VL-TONE
Casio PT-50
Arturia Microbrute
Nintendo DMG - Band: Hāzia
Re: Roland RS-09 Popping Sound when playing keys
I've read threads to this effect before, and one thing I have seen suggested repeatedly is trying to adjust the envelope timing. I have no experience with the RS-09, but my experience with old Roland gear suggests there may very well be an internal trimpot especially for this purpose - if you tweak the attack on the envelope generator just a hair above the zero mark, it may soften the EG just enough to fix it.
The VCA may also be needing calibration, if there is a trimpot to adjust that, try playing some notes while making adjustments to that - this may also fix the problem.
I hope this is maybe of some help. I sympathize with your frustration.
Good luck!
Good luck!
