korg R3 freeze
korg R3 freeze
Some of the preset patches cause my R3 to freeze up? Any fix? I tried a factory reset. No go! Is there a hard reset? Thx.
Onlinemeatballfulton
- Gear: Logic Pro X
Re: korg R3 freeze
Please be more specific.
1. Certain presets cause the R3 to lock up...which ones?
2. Factory patches?
3. Powering unit off and on, does it work after that?
4. If you run the editor software, can it connect to the R3?
Etc.
2. Factory patches?
Etc.
Re: korg R3 freeze
Factory patches. And yes it will work fine after its turned back on. Will freeze up though if you go back to same factory patch. I will list the patches soon. Thanks . I don't have the editor software yet. I bought the synth used with the issues hoping to fix.
Re: korg R3 freeze
I-4 cyborg makes the synth freeze.
- Gear: Logic Pro X
Re: korg R3 freeze
When you get the editor also get the latest OS. I'd try reloading the patches from the editor and see if that solves the problem. Since all patches can be overwritten, it's possible that they somehow got corrupted.
Re: korg R3 freeze
Thanks! Will do.
Re: korg R3 freeze
Hi there.
I have also bought an R3 with similar issues.
The unit will power on and work fine for a few minutes, then freeze up totally.
Issue doesn't seem to be patch related.
I've restored factory settings, opened it up to see if it was full of fluff but as of yet no luck.
Just wondering if anyone had any tips as to how to fix?
