Connecting Akai S2000 to Novation Launchpad
mm1
Post by mm1 » Fri Dec 04, 2015 11:39 am
So I have an S2000 sitting in my studio & I thought instead of paying $500AUD for an MPC unit, I would just get a midi pad for $150 & just use that. I'm wondering if there's a way to get the two devices to talk to each other, do I have to do any sort of programming in the S2000 or can I just connect the two devices via MIDI?
Calgonstudio
Real name: Ric
Band: Client No7
Re: Connecting Akai S2000 to Novation Launchpad
Post by Calgonstudio » Fri Dec 04, 2015 2:43 pm
I can't say for sure but if you have a USB to Midi convertor cable it should work.
I hooked a MPD26 up to my S5000, that I borrowed from a friend used that for a while to see if I would like it for drums better then a Keyboard. same concept ... I think.
mm1
Post by mm1 » Fri Dec 04, 2015 2:51 pm
Alright, that sounds simple enough, I've got one of those.
Post by madtheory » Fri Dec 04, 2015 5:06 pm
It's not as simple as it sounds. This WON'T work:
but this KENTON box will.
Post by meatballfulton » Fri Dec 04, 2015 6:47 pm
Good idea, except the Launchpad is a bad choice for your application:
First it needs power over the USB connection.
Second it wants to connect to a USB host (see the link to the Kenton box above, there are others).
Third the Launchpad is customized by a script being run on the computer it is attached to...obviously a problem when there is no computer!
If you just want a MIDI pad controller, look into something like the Arturia Beatstep, which even includes a step sequencer and is cheaper than the Launchpad although with fewer pads.
Post by madtheory » Fri Dec 04, 2015 7:18 pm
A small point- the Kenton box can do USB power. Ya Beatstep is much cooler- isn't there a free one on the other thread?
mm1
Post by mm1 » Sat Dec 05, 2015 6:00 am
madtheory wrote:It's not as simple as it sounds. This WON'T work:
I've actually had trouble with those leads before, I bought an M-Audio Uno to replace it. they're much cheaper than the midi host boxes.
