Proteus-3 power supply
Posted: Sun Dec 27, 2015 5:12 am
by cornutt
Anyone know what voltages should come out of the power supply on a Proteus-3? Thanks.
Re: Proteus-3 power supply
Posted: Sun Dec 27, 2015 9:35 pm
by Yekuku
Hi,
I cant be of much help since I have not seen a proteus PSU, but the e4 series of samplers use a switching mode PSU that deliver +12V,-12V, +5V, -5V.
If I remember correct the-5V goes to the DAC .
I hope this might help a bit.
Posted: Mon Dec 28, 2015 12:05 am
by fh991586
My Proteus FX uses a 9VAC 1amp external psu, if that can be helpful.
Posted: Tue Dec 29, 2015 10:59 pm
by raito
Why yes, yes I do! Helping out someone else isn't bad for a first post, now, is it?
The Proteus 1/2/3 use the same power (and are the same other than ROM -- that Proteus 3 is pretty rare). I don't think the XR models are any different, other than the expanded memory.
The power is on a 6-pin connector. Here are the voltages:
1 +12V
2,3 +5V
4,5 COM (Ground)
6 -12V
The original power supply may be a Skynet SNP-9031. You can still find them, if you look.
This purports to be original:
ZV311 at EPR Electronics
These may be compatible, and less expensive:
Mean Well PT-45B at Jameco
Artesyn LPT62 at Mouser
The power supply is the weak point of these units. From info on the net, recapping helps. In my case, I think the regulators may be the trouble. When my Proteus fails to boot, I only get a couple volts on the 12V rails. When it does, I get 13.5 or so. Other have trouble with sag.
Here's some other informative links on this:
http://robertgpatterson.com/techtipsfaq.html
https://www.gearslutz.com/board/rap-hip ... splay.html
http://electro-music.com/forum/topic-25815.html
http://electro-music.com/forum/phpbb-fi ... ew_803.jpg
