Need a part for minimoog D
passepassecom
Post by passepassecom » Sat Jan 16, 2016 11:16 am
Hi everybody
I'm a new french owner of a Minimoog D synth.
I must change some parts on the keyboard.
Anyone know which is the name of this rubber parts ?
Where can I find it ?
Thanks a lot for your help !
(I'm desesperate because I've waste a lot of time to search it on Internet...but nothing)
WhinyLittleRunt
Re: Need a part for minimoog D
Post by WhinyLittleRunt » Mon Jan 18, 2016 8:38 pm
Those are the actuators that pull the contact springs to the buss bars when you press a key. Probably not going to be easy finding them... you might want to try contacting CAE Sound or Syntaur to start... I was working on one a few years ago trying to fix a key issue and lost the rubber trigger dome that sits under the key... I was fortunate to have Kevin Lightner, who has since passed, send me a few of them to save my a$$. The Minimoog Pratt-Read keyboard assembly differs greatly from the standard ones you see on ARPs and SCI units; those rubber parts are not common. I wonder if they changed the type of assembly near the end of production at all? Maybe someone else who has a late-model D would know. The Mini uses spring contacts where the majority of PR assemblies use J-wire contacts.
Either way, good luck.
sequential circuits prophet t8 | oberheim ob-8 | moog minimoog model d | moog opus 3 | yamaha s90es | yamaha cp30 | arp omni-2 | linndrum | roland cr8000 | korg kr55 | simmons sdsv | 82 rhodes mark II stage | wurlitzer 200a | hammond m100
Broadwave
Real name: Andy
Gear: Kronos 2-88, System 8, MODX6, ARP Odyssey, BroadWAVE ARP 2600EX, BroadWAVE Modular, BroadWAVE Sparta, BroadWAVE Minimoog, oh... and some guitars.
Post by Broadwave » Tue Jan 19, 2016 8:38 am
WhinyLittleRunt wrote:The Minimoog Pratt-Read keyboard assembly differs greatly from the standard ones you see on ARPs and SCI units; those rubber parts are not common.
I've never been able to source these :(
MKI (White Face Odysseys) also use the same assembly - I've fixed a few in the past using 2 or 3mm thick neoprene strips (cut from a sheet), the actuator pin hole was made with a rotary punch and the other end glued onto the main spring block with rubber cement.
Hope this helps.
solar1
Post by solar1 » Wed Nov 28, 2018 2:59 pm
I just registered here. I know its an old thread, but, I do have a small quantity of the actuators.
you may pm me if you wish
