DX7 no sound (i think it's not the Battery)
funkybunch
Post by funkybunch » Tue Feb 23, 2016 12:03 am
I get no sound on the DX7. Headphones and Volume out didn't work. The Battery have to be changed, but before i did a SysEx Dump for trying a few Preset Sounds. They are saved until i turn the DX7 off. I tried an initial Sound, without success. The local mode is on and the keys work. I also tried to play a track via midi.... nothing... :(
When i turn the volume up, the noise of the preamp will get a little bit louder. But that's all.
Anyone has an idea what might be the cause? :?:
JeEA
Re: DX7 no sound (i think it's not the Battery)
Post by JeEA » Tue Feb 23, 2016 2:24 pm
Have You changed the battery.
Data Will be garbish if the memory backup is gone.
I would change it and dump sounds to it via sysex
and try again to see if it had helped.
Cheers
huntercomplex
Post by huntercomplex » Tue Apr 05, 2016 9:18 pm
I have the same problem. I just had the battery replaced, but that didn't solve the problem. Any help would be very much appreciated!
gslug
Real name: Kevin
Gear: Jupiter 6, Juno 106, MKS-50, DX7, TX81Z, Emulator II (dead), DPX-1, EPS 16 Plus, x0xb0x, Shruthi, TR-707, 9090, MIDIbox MB6582, MIDIbox Seq V4
Post by gslug » Thu Apr 07, 2016 9:59 pm
There is a relay on the output of the DX7, intended to mute it during power down. Mine occasionally fails to unmute on power on, so I'd suspect this. I keep meaning to replace mine, but haven’t been able to find a part number. You could probably get away with removing it and bridging the appropriate pins.
