Yamaha ex5 problem
MCariCooper
Yamaha ex5 problem
Post by MCariCooper » Sun May 01, 2016 1:45 pm
So I recently bought a yamaha ex5. When I bought it everything worked on it. Then when I got it home and turned on and the screen said now executing then it switched and said power off at once. Now I don't know what to do.
db0451
Re: Yamaha ex5 problem
Post by db0451 » Sun May 01, 2016 7:13 pm
Have you powered off and back on? I ask because it sounds like you have left it on, and the message sounds like one that comes up if you power on while (in this case accidentally) holding down a particular combination of buttons to perform a factory reset. One would then assume that if you restart without holding any buttons, it will boot normally.
MCariCooper
Post by MCariCooper » Sun May 01, 2016 7:17 pm
Yes I have tried that
Werecow
Real name: Brian
Post by Werecow » Sun May 15, 2016 9:27 pm
The only thing that comes to mind is something along the lines of what db suggested. The keyboard may have bumped something during transport, and a button or two may be jammed in the down position.
