Casio CZ-3000 MIDI Question
Postby petey_kid » Tue Nov 01, 2016 12:55 am
I was given this synth as a gift, I've been noodling around with it and most recently trying to use it with FL 12 on Windows 10, but I'm having trouble getting any MIDI in to the PC at all. I'm running it through one of those little mio iConnectivity cables, which MIDI-OX recognizes but I get no data readings from the synth. Can anyone advise me on this? Sorry, I'm pretty much a dolt with this stuff.
petey_kid
Re: Casio CZ-3000 MIDI Question
Postby High_Treason » Tue Nov 01, 2016 1:32 am
This stuff is all after my time, so I have no idea how FL Studio works, having only borrowed it and used it once before I went back to where I came from. Supposedly though, there should be an Options menu with MIDI settings in it, you can set the input to your, presumably, USB-MIDI wire there.
Be sure you have the MIDI IN cable connected to MIDI OUT on the keyboard and that you set the channel in the keyboard's MIDI page correctly, KBCH is the one for output. Past that you're probably using VST's or something and you might need to set them individually, I've no real experience there either so can't really help on that one.
There is another thing, try power cycling the keyboard - sometimes an application sets it to "remote control" so the keyboard on it won't work anymore, it is easier to power cycle the instrument if you don't have quick access to the controllers to set it back. Cakewalk 9 does this to any synth I hook up and it's annoying... Mostly as I'm sure it can be disabled but I can't be bothered to look in the menus, not that this helps you any in FL 12, but the same thing might be happening I guess.
High_Treason
Gear: Casio CZ-1, CZ-5000, RZ-1.
Yamaha MU90R, SW1000XG.
Korg O1R/W
Roland SCC-1
Postby petey_kid » Tue Nov 01, 2016 2:21 am
Can't believe it was a simple as power cycling the keyboard, slightly embarrassed but it's outweighed by relief that its working. Thanks dog, I'm gonna go play in my new sandbox now. :D
petey_kid
Return to HELP!
Users browsing this forum: Baidu [Spider] and 1 guest
