I have filmed myself creating a pattern from scratch with the only Raveolution309. You will notice the lack of compression and sometimes PCM's can sound very loud.
That machine is a beauty with a lot of little bugs, you will hear the sequencer stopping/slowing down when I change part, sounds from a part can cut the ones from other parts, many sounds irregularities etc... this machine is alive!!!
I can play like that during days only with that baby, I do not produce good techno but these oldshool sounds remember me the golden age of techno... I miss Quasimidi
DEMO request
Posted: Thu Mar 08, 2007 9:25 pm
by cbjlietuva
OK, this is what i'm after, and first off, i know these are two different generations of synth, blah blah blah
I want to hear a jupiter 8 & an Andromeda side by side, patched as close to similar as they can be, for a test of their timbral qualities, doesn't need to be anything fancy, just a nice test of they sound of the oscillators and the filter(s)
CBJ
Posted: Thu Mar 08, 2007 11:35 pm
by Shleed
Another video of the MFB Synth II in action, the audio is perfect but this time the video quality is kind of s**t. (webcam...)
The Roland D-10/20 is a very underrated synthesizer.
Below is a demo of what it can really sound like.
It is made in Cubase, and I have added a bit of
reverb. Some of the patches uses the D-20s delay.
(Needless to say, the presets are real crappy)
I have created all the sounds myself, except two.
In order to make good use of the Roland D-20,
it is better to overlook its multitimbral
capability. I use the performance mode to layer
the tones, thereby making the sound fatter.
Ignore the multitimbrality, the sequencer, and
the drum machine. The Synthesizer is good on its
own.
If anyone wants to have these sounds, drop
me a PM and I will send them to you.
Introspectiv 9090
Posted: Sun Mar 18, 2007 6:36 pm
by nathanscribe
Given the relative scarcity and high price of Roland TR-909 drum machines, Trevor Page of Introspectiv has put together a clone for the advanced DIYer. Not cheap if you do it right, and not easy either, but it fully replicates the original circuits, including the sampled hats and cymbals. This has taken me almost a year to build, on and off, including troubleshooting and cabinet making and all that.
Finally though, it is integrated into my setup. Currently plonked on top of one of my racks. Have a listen to this short demo. Not the most amazing programming on my part, but it does the job
these are made using the onboard sounds only
I erase the factory patterns that come with it 1st thing.
These are both programmed and sequenced by myself, and recorded in one take with no edits, fx, compressors or EQs other than the onboard fx of each unit. I am not using both at once, these are seperate demos of each.
The tubes (Valve Force) are set to no more than 10-15% gain.
ESX-1 - trance-y tune I made called SWEETPEA the bit-crushing towards the end turned out nice imho
Everybody has heard the Sunsyn's aggressive sound, so I decided to make some softer demos, with reverb, for your listening pleasure Ok, the sync sound isn't soft, but I'm a sucker for sync sounds.
I'll try to make some better quality examples when I get my proper audio interface running. Sometime next week... Maybe
- CM
Re: Softer side of Sunsyn
Posted: Sun Apr 15, 2007 8:23 pm
by Soundwave
Carey M wrote:Everybody has heard the Sunsyn's aggressive sound, so I decided to make some softer demos, with reverb, for your listening pleasure Ok, the sync sound isn't soft, but I'm a sucker for sync sounds.
- CM
Sounds very much like a polite Memorymoog or maybe a Prophet 5! 8)
Posted: Sun Apr 15, 2007 9:04 pm
by Carey M
Soundwave wrote:
Carey M wrote:Everybody has heard the Sunsyn's aggressive sound, so I decided to make some softer demos...
I've never actually played a Memorymoog, so I couldn't tell, but I have to disagree about the Prophet 5 comment. At least compared to any CEM Prophets, the Sunsyn is a lot "cleaner" and "refined". Then again, two of my friends claim to hear something "Prophety" in the Sunsyn, so maybe I'm just deaf. Nevertheless, I'll take your comment as a compliment
For additional Sunsyn demos, I'll recommend these two:
