I decided to start a series this year in which I will show an interesting patch each month. I think it's mainly gonna be interesting patches on the modular or other fun routing scenarios across the various machines in the studio. They're not product demos but also not full tracks, kinda something in between coaxing juicy sounds out of creative patches. Usually I'll do minimal editing and I'll describe the patch so people can grasp what is going on. Hope you enjoy this, any and all comments are very welcome!
EDIT: Gonna continue this.
I was experimenting with no-input feedback patches using the A199 spring verb and RES4 resonator a lot recently, so that's gonna be the first patch. It's a bit hard to control the feedback bursts so I wanted to get a compressor into the feedback path. As I don't have one in modular land I decided to patch the feedback loop out to my Warm Audio WA76 to tame the feedback.
The patch is relatively simple, it's just a RES4 in the feedback loop of an A199 without any input source, with the WA76 before the RES4. It's really smashing the sound with the "all buttons in" mode to tame everything. Three bands are used from the RES4, tuned to three different octaves. An RG6 is at the center of the patch, selfmodulating and also syncing itself (with the gate out, relatively high threshold) which brings a bit of repeatability to the random generator. The RG6 clock output triggers a Maths envelope which gates the RES4 via the internal master VCA. An S/H output from the RG6 is sent to a Quantimator in "arpeggiator" mode and then the three quantized outputs to the three RES4 frequencies for the rotating melody.
I've added a gated noise (from the MS20) after the feedback loop to produce some attack transients at each start of a new "note". So it's not in the feedback loop but just mixed in with it afterwards. It's triggered by the second Maths envelope and fed through a SPH2 for a bit of variation. I find it nice to signify new notes and also give a bit of a "overblow" feeling like in brass and wind instruments.
I'm changing a few things here and there, mainly the envelopes, RG6 frequency (i.e. master clock speed) and the master pitch (via Maths offset into RES4 master frequency input). Bit of Ableton EQ and compression to further tame those transients and some reverb and delay for the spaciousness. Minimal editing in this one. The A199 and WA76 squashing raise the noise floor quite a bit, cannot do much about it but I like the patch nevertheless.
Hope you enjoy it, cheers!
https://soundcloud.com/contracommunemop ... -orchestra
