My take on Equinoxe IV ;-) (analog, almost live ;-) )
Come here for topics reviewing and sharing songs, tracks, music, synth demos, etc.
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
Solton Programmer 24
LEMA EDD-5
Post by adamstan » Wed Apr 08, 2015 3:35 pm
Two takes, recorded to Portastudio 464.
First take (upper left picture):
  • trk 1: "Arpeggiator" - B5
  • trk 2: Strings in the "verse" and lead in "chorus" - Korg Poly61
  • trk 3: Drums - APS Mini Rhythm MR3201 (disco pattern with snare turned down)
Second take (upper right picture):
  • trk 4: Bass - Poly61 / Pad - B5
Delay effect used was ADS Digital Delay 500 - very lo-fi sounding unit, as it is built around simple sigma-delta ADC.
Bottom picture was shot during mixdown. No sequencer has been involved*
Poly61 hold mode and ability to switch patches using footswitch provided really useful :-)
* sounds like those "No Fairlight on this record" annoucements** ;-)
** but, honestly, playing the arpegiattor part was real PITA ;-)
synthroom
Real name: Kirk
Re: My take on Equinoxe IV ;-) (analog, almost live ;-) )
Post by synthroom » Thu Apr 09, 2015 6:17 am
Thanks for posting! I enjoyed listening and watching it!
ned-ryarson
Post by ned-ryarson » Thu Apr 09, 2015 4:28 pm
Much of it sounds out of time
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
LEMA EDD-5
Post by adamstan » Thu Apr 09, 2015 5:36 pm
Could you please elaborate on it? I'm aware of some missed notes in the "arpeggiator" part, and there is obvious error that was pointed out to me by one of the listeners - staccato "lead" in D-minor chorus should be played in triplets, and I played it with combination of sixteenth- and dotted eighth notes. And strings are sometimes one-eighth late after downbeat - but that was deliberate. So these are errors/departures from original I'm aware of, however to my ears it still sits on the grid most of the time.
ned-ryarson
Post by ned-ryarson » Thu Apr 09, 2015 7:03 pm
adamstan wrote:Could you please elaborate on it? I'm aware of some missed notes in the "arpeggiator" part, and there is obvious error that was pointed out to me by one of the listeners - staccato "lead" in D-minor chorus should be played in triplets, and I played it with combination of sixteenth- and dotted eighth notes. And strings are sometimes one-eighth late after downbeat - but that was deliberate. So these are errors/departures from original I'm aware of, however to my ears it still sits on the grid most of the time.
The initial arpeggio you play is not 'on the grid'. In the original it is
adamstan
Real name: Adam
B5 DIY polysynth
KORG Poly61
Vermona DRM
LEMA EDD-5
Post by adamstan » Thu Apr 09, 2015 7:18 pm
Thanks. Now, when I listen more carefully I hear it. You're right, arpeggio in the first "verse" is quite sloppy - actually, it's worse than I initially thought it was :oops: In addition to missed notes, there are some that are played too early - my bad.
ned-ryarson
Post by ned-ryarson » Thu Apr 09, 2015 11:10 pm
Sorry to only highlight the negative by the way, i didnt have time to flesh out my comments. Its a really enjoyable performance otherwise, I've watched it a few times now. Keep it up!
