zielvis wrote:Hello,
I need to buy an audio interface - if anyone can provide me with some advice, I'd be grateful
I can buy Edirol UA 25 for about 200 $. Do You think it's a good idea? Anybody's got experience with this interface?
Let me add, that:
- I need to be able to record in stereo my synth(s) and groovebox(es) and guitars,
- I will use it with MacBook Core 2 Duo, 2 GHz (in case it makes any difference) and Logic and/or Live
- I'm also considering Line 6 UX 2 - it has all those guitar amp simulations etc. as a bonus but it's not a must for me.
Do You recommend any of those two - or maybe something else (in similar price, please) ?
What do You think? Thanks in advance.
Marcin
I have the UA-25 and it's a geat little interface.
I'm using it on a PC but I'm sure it will work fine on a Mac too.
Some notes:
- Although it's marketed as a 96KHz interface, you can only either record or play on it at 96KHz. For full duplex operation (play and record at the same time), you will have to switch down to 48KHz
- decent enough (not noticable) latency figures (input latency: 7.5ms, output: 5.3ms @48KHz full duplex)
- Balanced inputs and outputs (very nice
, you don't get that on all units in it's range)
Overall I would say it is perfect as a 2 in 2 out 48KHz interface.
Do you need Firewire? Not for 2 in 2 out 48KHz sound + MIDI in and out.
If you want more, I guess you will need Firewire or USB 2.0
To get the Firewire vs. USB discussion a bit in perspective again,
this is a USB1.1 device not 480, not 400 but a mere 12 Mbps.
Nevertheless it's doing fine for what it is.
Tidda
